Sealant for End Cap May 22, 2020, 04:26:41 pm I discovered a small gap at the side of one of my end caps. Besides that the end caps look quite good (they were being resealed by Lazy Daze about 2 1/2 years ago).Is "3M 5200FC Fast Cure" the right sealant for this? Or is there something else that is better? Do I have to scrape off as much as possible of the old dry stuff that is in that area, or can I apply the sealant more or less on top of it?Klaus
Re: Sealant for End Cap Reply #1 – May 22, 2020, 04:51:37 pm It's difficult to tell how large the "small gap" is from the photo, but, if the factory sealed the end caps when you say, they missed a spot! Scrape out the old sealant and any dirt and goop completely, clean the surfaces thoroughly with acetone, apply blue tape to both sides of the gap, leaving about an 1/8" space to fill with sealant, then shoot 3M 5200 Fast Cure into the seam. Be sure that it fills the gap completely. Smooth out the line; remove the tape after about an hour or a bit more. Pull the tape away from the newly-sealed seam when removing it to prevent any possibly still tacky sealant from "stringing".You might want to expand the project to include *all* of the caps; if one area of the end caps is in the condition suggested by the photo, it may well be that other areas will follow it pretty shortly! 2 Likes
Re: Sealant for End Cap Reply #2 – May 22, 2020, 10:09:10 pm I would do the whole end cap, both edges and both sides ( driver and passenger) Jon
Re: Sealant for End Cap Reply #3 – May 23, 2020, 12:04:48 am Quote from: Klaus - May 22, 2020, 04:26:41 pmI discovered a small gap at the side of one of my end caps. Besides that the end caps look quite good (they were being resealed by Lazy Daze about 2 1/2 years ago).Is "3M 5200FC Fast Cure" the right sealant for this? Or is there something else that is better? Do I have to scrape off as much as possible of the old dry stuff that is in that area, or can I apply the sealant more or less on top of it?KlausSearch endcap and its iterations and you will find many discussions on this topic.Chris
Re: Sealant for End Cap Reply #4 – May 23, 2020, 01:31:51 pm KlausA rig as old as yor should have the end caps and the window frames resealed. You don't want to repeat the rot experience of downgrader and many other owners of older rigs. It's a lot easier to reseal than to repair.There are dozens of posts on resealing both the caps and windows to be searched for.Larry 3 Likes
Re: Sealant for End Cap Reply #5 – May 27, 2020, 09:13:20 pm Often you can secure caps as the sealant cures without screws. As an example, I pulled out most of the lower rear end cap driver's side to reseal, then secured it with rope, adjustable clamp, and 2X2" aluminum angle stock:Steve 7 Likes
Re: Sealant for End Cap Reply #6 – September 21, 2020, 10:57:14 pm Quote from: Larry W - May 23, 2020, 01:31:51 pmKlausA rig as old as yor should have the end caps and the window frames resealed. You don't want to repeat the rot experience of downgrader and many other owners of older rigs. It's a lot easier to reseal than to repair.There are dozens of posts on resealing both the caps and windows to be searched for.Larryam downgrader, can confirm 😭
Re: Sealant for End Cap Reply #7 – October 10, 2020, 11:59:42 pm I'm curious why the mothership uses plastic end caps? Surely this would last longer with an aluminum end cap? And would have similar coefficients of expansion. I'd love to hear others thoughts...
