Sewer Hose Fitting Question May 21, 2020, 09:02:48 am The campground I will be going to requires a sewer hose fitting for the sewer at the RV site. I have the Lazy Daze hose. What will work for that hose which does not have anything at the end? I haven't needed this before but will be camping with my two young adult granddaughters and we will be using lots of water so I want to use the sewer on site. Thank you for any recommendations.Monica
Re: Sewer Hose Fitting Question Reply #1 – May 21, 2020, 10:02:22 am Quote from: rvhiker22 - May 21, 2020, 09:02:48 amThe campground I will be going to requires a sewer hose fitting for the sewer at the RV site. I have the Lazy Daze hose. What will work for that hose which does not have anything at the end? I haven't needed this before but will be camping with my two young adult granddaughters and we will be using lots of water so I want to use the sewer on site. Thank you for any recommendations.Several places we've been require an air-tight connection to the sewer (usually a county or state law). A few places won't even allow the sewer hose to lay on the ground (it must be supported somehow). Most parks have one of the following: a 4" unthreaded sewer pipe, a 4" threaded sewer connector or a 3" threaded connector. For most of the time we were in our LD, we used the Prest-O-Fit sewer hose products.Blueline RV Sanitation â RV Sewer Hoses, RV Sewer Fittings, Supports and...With the threaded sewer adapter off, the sewer hose fit into the LD's sewer hose storage. For places with an unthreaded sewer connection a rubber adapter (typically call a "doughnut") can be used.Sewer DoughnutHTH,Art 2 Likes As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Sewer Hose Fitting Question Reply #2 – May 21, 2020, 10:36:51 am Valterra offers an extensive line of sewer hoses and fittings, but Art's suggestion of the Presto-Fit couplers might be a better choice because I don't know if the new style "E-Z Coupler" hoses and pre-attached end fittings are too large to slide into the sewer hose tube in the LD. Sewer Fitting Archives - Valterra.comEZ Coupler Bayonet Sewer Hose Kit, 10′, Boxed - Valterra.com
Re: Sewer Hose Fitting Question Reply #3 – May 21, 2020, 10:49:39 am "Most parks have one of the following: a 4" unthreaded sewer pipe, a 4" threaded sewer connector or a 3" threaded connector."Most parks have a small (or large) convenience store that carries items such as that. If the owner has any business acumen he will provide a good selection of RV related items for his customers and will recommend the appropriate type of connector.
Re: Sewer Hose Fitting Question Reply #4 – May 21, 2020, 11:04:34 am Thank you, Joan, for your recommendations.Thank you Steve, but the convenience store at the campground where I'm going to in NY is not open because of the pandemic. Restrooms and amenities like pools are likewise closed. Campgrounds in NJ are still closed. Monica
