Topic: Source for larger gauge zip wire for portable solar panels (Read 178 times) previous topic - next topic
I have a portable 200 watt solar cell setup I will be using with my rig. At some point I may go with a permanent install but for now I will just hook up the panels when I go boon docking. I need to buy some flexible wire to  connect them to the controller when in use. I'm trying to find a larger gauge (6-10 gauge) zip wire instead of two separate cables for convenience but I'm not having much luck finding anything. I have found larger gauge extension cords but they would include a third conductor for ground.
Has anyone come across a source for such a cable?
2003TK
Re: Source for larger gauge zip wire?
Landscaping lighting wire, or Malibu wire, is what you want. It's available in as thick as 8/2.
Home Depot and other hardware stores will have or carry it up to 10/2.
10/2
https://www.homedepot.com/p/Southwire-250-ft-10-2-Black-Stranded-CU-Low-Voltage-Landscape-Lighting-Wire-55213501/204210683
8/2 wire
Amazon.com : Paige Electric 8-2 Low Voltage Landscape Lighting Wire - 100FT...
When running new 12-volt circuits, landscaping lighting wire is my favorite, it has a very tough outer coating, designed to be buried.
Great options, thanks to both of you!
2003TK
Re: Source for larger gauge zip wire for portable solar panels
Landscape wire will work in this application, but it's designed to be buried and left in place--not laid out in the sun and moved around. I prefer marine-rated jacketed two-conductor wire. The outer jacket provides abrasion and UV protection that you don't get with zip wire. The cable is somewhat stiffer than zip wire of comparable gauge, but I haven't found that to be a problem.
Andy, great tip (as usual). I searched for other sources and found that West Marine carries some of the gauges and sells it by the foot online ANCOR Flat Safety Duplex Cable by the Foot | West Marine .
Charles
Escapees SKP #138195
2007 23.5' Twin King
High-quality landscape wiring is designed for both direct burial and above-ground use, also being UV resistant.
Our house was wired for low-voltage lighting over twenty years ago and the above-ground wiring is still in good shape, if it last that long in our hot climate, occasional use with solar panels should be fine.
12/2 250 ft Direct Burial Cable for Landscape Lighting | VOLTĀ® Lighting
Either type of wire is going to work with portable solar panels, with similar results.
For 200-watts of panel, use the 10/2 wire for the lowest voltage drop.
