Topic: Roller Shade 2005 (Read 159 times) previous topic - next topic
Roller Shade 2005
Hi,
I have a roller shade issue in my 2005 RB. The shade does not work. It will go down but will not spring back up. I think the problem is a combination of the actual roller shade not wound up properly and maybe a broken mounting bracket.
Can anyone look at the picture below and tell me if the mounting bracket is broke, or is that the way it usually looks?
-Joe
2005 26.5 RB
Re: Roller Shade 2005
The bracket shown is damaged ad may be the reason why the shade doesn't work right.
Roller shade brackets are available at any hardware store that sell roller shades.
I suggest replacing the shade too, it looks like has seen a hard life, getting caught in the door. It doesn't need to come from the Mothership, your local hardware store can cut a new shade to size.
I would remove the bracket and see how the tab on the shade fits. If it looks like it may rotate when installed, you may be able to squeeze it a bit to grip, as a temporary fix, if you can't find a new bracket right now...
