Topic: Tire pressure in winter (Read 201 times) previous topic - next topic
The last time I checked my tire pressure was in November when we usually had 70-75°  in the afternoon and rarely below 50° at night, and I adjusted it to 75 PSI. Since then the rig was parked in my driveway. Now I checked the tire pressure again and had 70 PSI on all tires.
Today the temperature did not go over 50° in the afternoon; at night it sometimes goes down to around 30°. I'm wondering whether the lower pressure has something to do with the temperature. I'm not sure whether the pressure dropped by 5 PSI within two months before (I had the rig standing in my driveway for some months before).
I'm planning to leave for Quartzsite tomorrow or on Tuesday.
Question: Should I put the pressure back to 75 PSI regardless of the outside temperature in the afternoon, or should I stay a little lower?
Thanks, Klaus
PS: I just researched this elsewhere (Internet!) and learned that at wintertime the tire pressure should be higher than at summertime. Makes sense (when thinking it through). I guess I should bring the tire pressure up to 75 PSI again - or go even a little higher, right?
2001 26.5 Mid-Bath
Re: Tire pressure in winter
Set it to 75 psi and then don't be concerned about small fluctuations.  Check it at the same time of day when it hasn't been driven.    Lower temperatures will bring it down slightly, higher temperatures and driving brings it up slightly, and over time some air molecules will get out.   During a year or so you may loose 2-3 pounds (guessing on that) assuming there are no actual leaks.     Frank
plan B - 2023 Travato
Changes in elevation will cause small fluctuations also.
I believe that a person can pick too many nits if given the opportunity!   ::)
