Topic: Headlight 'restoration' product (Read 460 times) previous topic - next topic
I know that this topic has been worked over quite a few times (and the prevailing option was to replace the headlights instead of trying to 'de-yellow' the covers), but I saw this product and wondered if anyone had used it and, if so, what their experience was?
Headlight Restore Kit - M4 Products
Re: Headlight 'restoration' product
I just ordered one. I’ll let you know how it works. I’ve got pretty yellow lenses on my ‘06. — Jon
Thanks, Jon! The lenses on my 2003 aren't really bad, and I don't drive at night, but they could use a bit of 'brightening'!  ;)
Jon,
I wasn’t able to determine if a sealant was included in your lens cleaning kit. Meguiars makes a sealant spray for DIY headlight cleaning.
I recently replaced my Avalon lenses after having polished them several times in the last few years. They always yellowed again within a few months. Scotty Kilmer recommended the Meguiars sealant. It should be applied after the cleaning is done. Applying it every year is supposed to eliminate future yellowing. Amazon.com: Meguiar's G17804 Keep Clear Headlight Coating, 4 oz. – Maintain...
I used it on my Avalon’s new lenses and my ‘15 LD lenses as a preventive measure. I’ll reapply when the time comes. If it keeps them from ever yellowing it will be worth the $8.00 I paid. I did four headlights and there is still product in the can.
An ounce of prevention...
Kent, the product packaging indicates 3 steps: clean, dry, coat. The last is some sort of UV shield. I guess only time will tell. — Jon
I saw the headlight restore product at Sema last year.  It really worked on some old lenses, but man was it stinky.  Just about passed out when he opened the sealed bag.
Kent, I do get a kick out of Scotty's videos and he does know his "stuff". I'm going to get me some Meguiars.
2003TK
While my LD is parked uncovered in storage, mostly summer months, I lift the hood and attach (a small slit on each side) a sheet to the hood cushions and close the hood. The shortened sheet covers all the front lenses.
Thanks, Jim!
Refinishing sun damaged headlight is an act of futility, the results will be short term and the light pattern will never be as good as new.
Headlights are manufactured with a thin coating of ultraviolet resistant material, this surface is what is damaged and removed when refinishing.
Once the outer coating has been removed,  the underlying plastic, which isn't ultraviolet resistant, will quickly decay and yellow. None of the kits come with a replacement ultraviolet resistant coating.
Additional polishing will completely destroy the headlight's light pattern. BTDT too many times.
The cure is a tough one, buy new headlights.
Hi Larry. This Meguiar's kit does come with a spray can of UV resistant coating. It does work. I used it on my Tacoma truck about a year ago.  Meguiars also says to repeat the coat every year, and they mean it. It does start to cloud up and yellow after a year. I recleaned one lens (they are small compared to the size of the motorhome headlight) and repolished and recoated it. Still need to do the other one.  Count on that being a yearly thing.  Eventually you will end up replacing them anyway.
     I replaced the headlights on Bluebelle, took longer, more expensive, but a better solution in the long run. No polishing, no masking, no overspray, no bugs stuck to the lens, etc.     RonB
