Topic: Suburban Thermostat Off Switch Failure (Read 402 times) previous topic - next topic
We have a 2014 MB with a Suburban Furnace.
Back in July we ran the furnace in the morning to warm up the coach a bit, and then moved the thermostat switch back all the way to the left to shut it off, but this had no effect.  We ended up having to pull the fuse from the 12V side of the main panel to shut it off.
Anyone else have this problem?  I'm currently scoping out the technical info online to see if I can get some procedures to isolate the problem.  Will report back if I find anything out.
Thanks,
Tim
2014 Mid-Bath
2014 Honda CRV toad
Re: Suburban Thermostat Off Switch Failure
The thermostat has a "slide" portion and an "Off" position.  If you slid the tab to the left until it stopped, but not far enough for it to click, you did not get it to the "Off" position.  If you felt the click as you slid it to the left, and it kept running, that sounds like a thermostat failure.
Ken F in NM
Ken,
Yes, we slid it all the way left and clicked it into the off position, so I agree that it seems like a thermostat failure.
Thanks,
Tim
2014 Mid-Bath
2014 Honda CRV toad
After turning off the furnace at the thermostat, the fan will continue to run until the flue temperature falls below 300F, which can be a couple of minutes. The flame, however, should extinguish immediately.
Ken F in NM
Or a broken switch.   This happened to us around the first couple of times we used the Suburban.
glen
Steve,
Yes, that's right: however, the gas was not shut off, so this was definitely a problem.
As Ken mentioned additionally, the switch actually broke on him.  I'm going to try a test to further isolate the problem.
Tim
2014 Mid-Bath
2014 Honda CRV toad
Take one of the wires off at the t stat, gas should go off.
Or remove the fuse - like they did - to achieve the same effect. The switch on our 1993 was really primitive. It would be easy to see it breaking and or jamming an internal short.
I'm guessing RV thermos are getting to be like home units with more electronics. My motto was always to swap and forget - within reason. That is, I'd rather spend $30-40 bucks for a replacement part if I couldn't immediately detect what was malfunctioning.
You can get digital thermostats at Walmart, Home Depot, and elsewhere for only $20-$25, and they work better than the old style mechanical thermostats, keeping the temperature within one degree or less of the setting, compared mechanicals 2 degrees or more. That smaller temperature swing means noticeably more comfort when heating.
2005 Jayco 24SS
FYI, I ended up purchasing a new Suburban (White-Rodgers) thermostat from Amazon ($19), identical to the old one.  Installed it and it works fine.
Thanks for all of your replies.
Tim
2014 Mid-Bath
2014 Honda CRV toad
The best outcome. Fixed the problem for less than $20 bucks.  It's rare, but thermostats do fail. Especially an old style thermostat. They're almost bullet-proof!
Bill
Bill
2003 -- 23' FL
