Topic: Any recommendations for a toilet replacement in a 2003 T/K? (Read 192 times) previous topic - next topic
Any recommendations for a toilet replacement in a 2003 T/K with a Whisper King pump and original SeaLand 510+ porcelain toilet?
Biggest problem I have with this original toilet is it uses a lot of water.  The way things drop into the bowl is not ideal and requires a lot of water to push/float those objects to the drain when times comes to flush.  The black tank in this T/K model is not very large and it seems like the black tank is more limiting in camping time then the gray.  The bowl is also not currently holding water so would rather solve a few problems at once and replace it something more water efficient.  Last fall I had to replace the original Whisper King pump with the spare Whisper King pump the previous owner had been hauling around for many many years.  The Whisper King pumps put out less water flow then some of the other models and is no longer made.  Anyone find a toilet that's more efficient?
JohnF
2003 T/K
2003 TK
Re: Any recommendations for a toilet replacement in a 2003 T/K?
Our '83 had the original Thetford toilet, all plastic, but much more water efficient than the Sealand model in our '04.
We always lay a few strips if toilet paper in the bowl for poop so it stays nicely wrapped up when flushing so we only add enough water for this little package to go down into the tank without leaving streak marks. 😀
Destiny is a matter of choices.
1993 22' TK
