Newer LD Heating and Cooling August 16, 2019, 01:47:19 pm On the newer LD's, my understanding is that the heating is ducted but the AC is not. Is that correct?
Re: Newer LD Heating and Cooling Reply #2 – August 16, 2019, 02:41:05 pm With a roof mounted air conditioner, ducting has to be through the ceiling. Because of the low height profile of the LD coachwork, there is insufficient height inside to support the 'false' ceiling necessary for ducting.Steve 1 Likes
Re: Newer LD Heating and Cooling Reply #3 – August 16, 2019, 03:03:07 pm Quote from: Steve - August 16, 2019, 02:41:05 pmWith a roof mounted air conditioner, ducting has to be through the ceiling. Because of the low height profile of the LD coachwork, there is insufficient height inside to support the 'false' ceiling necessary for ducting.Thanks, Steve. That's what I was thinking. I knew it was that way on the older models but wasn't sure if LD had changed over the years.
