Specs July 25, 2019, 04:48:56 pm I've checked several sources and can't find the back hitch weight for a rack on the back. Anyone know, or a source to check?Model: 2005 Mid-bath 27feet
Re: Specs Reply #1 – July 25, 2019, 05:23:13 pm Quote from: elsea - July 25, 2019, 04:48:56 pmI've checked several sources and can't find the back hitch weight for a rack on the back. Anyone know, or a source to check?Add the model and year of the LD to your signature for better results in requesting help.Larry
Re: Specs Reply #2 – July 25, 2019, 07:18:00 pm Hi Elsea. A 2005 MidBath is good for at least 350 pounds. A lot depends on the type of rack, and what the rack is holding. Heavy bicycles may swing back and forth a lot. You would have better luck mounting two receiver hitches underneath the bumper, to support a heavy object with two posts. RonB
