Topic: Replacing the curtain glides (Read 320 times) previous topic - next topic
Hi
I wonder if anyone is able to tell me how you replace the curtain glides.  I can't seem to figure out how to get the old glides off.  Many of ours have broken so the curtain aren't hanging nicely.  It looks like the only way to get them off is to take the curtain track off but I was hoping that there was an easier way that I may be missing.  We have a 2000 model with a metal track and have only had our LD a couple of weeks so very new to this.
Any help would be appreciated.
Many thanks
Peta
Re: Replacing the curtain glides
Hi
Many thanks
Peta
Peta, welcome to the Lazy Daze Owners' Group. Someone will give you an answer soon or could do a search for "curtain glides". What year and floor plan LD do you have?
Peta, you mean the plastic (or maybe metal pieces) that slide around inside of the curtain track?
In houses, often at the end of the curtain track is a cap that can be taken off (put a screwdriver into a notch and pop it off).
I just checked in our rig (89 TK), the curtain tracks seem to butt right into a wall/cabinet.  They do have screws that you can see if you look up from underneath. That would take them off (yup, a pain...., but I don't see another way).
Pictures would help.
Hi Peta,
I think my 2002 may have the same brown metal track as yours. When the first glide broke I searched the forum and found a message  recommending the RV Designer A103 below. They were too small so I ordered the JR Products 81085.  I found an old forum message that said you have to take the track completely off to replace the glides. I didn't want to take that on so I never did try the larger glides. What I wound up doing is ordering lined Pottery Barn curtains off ebay. I removed the curtains from the upper bunk and hung up the Pottery Barn ones. Actually I found this a better solution than the too short cab curtains. Now I can close off the cab area when running the A/C or heater for a more efficient use of energy and better privacy.
I have not tried this one but it looks like it might work. It's larger than the A103.
JR Products 81085
https://www.amazon.com/gp/product/B002UC6U5U/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
The RV Designer A103 below was too small.
Amazon.com: RV Designer A103 Drape Carrier - Small Sliding Eye #3, Pack of...
Hope this helps,
Langton
2002 27" RB
Hi
Many thanks for the replies and it looks as though the solution is unfortunately having to take the track off.  Thanks for the info on the size of the glides.
I like the idea of replacing the upper curtains instead.  Will look into that. Great idea thank you.
Regards
Peta
I was looking into replacing mine because one by one they are breaking. So I took a few pics and the way I was able to get one off was lightly unscrew the brace.
2000 RB
Hi
Regards
Peta
Peta, what year and model LD do you have? I'd like to add it to your profile.
Hi.  I've replaced the plastic hooks on two motorhomes, my '99 and a friends 2001 MB. I've never had to remove the track. The end can be unclipped from the hold down bracket, maybe you'll need to remove an end screw. All of the glides have to slide out, and new ones slide back in. I sewed clips from LD, directly onto the curtains. No metal clips. RonB from hotel lobby in Amsterdam. LD wouldn't fit here!
As of two years ago the gliders were available from the LD Factory. We found it best to replace all at one time on our 2000 MB.
2000 MB
