Topic: Solar Panel Stuff (Read 187 times) previous topic - next topic
Solar Panel Stuff
Although not an endorsement just a starting place for update information, learning and comparison shopping.
Renogy
There is a boat load of bad information on solar power and batteries.   IMHO one must have a very firm grip on your wallet at all times.   Check and double check.......
glen
Re: Solar Panel Stuff
I have 200 watts permanently flat mounted with a lithium/lead acid hybrid system. Works very well. Don't need it but would prefer more solar. Generator runs are usually less than 30 minutes/day now. My advice: no less than 200 watts, preferably more, and permanently mounted.
Harry 2006RB
Harry,  You are running your furnace all the time as you are in cold country if I remember right, is that correct?
The furnace is the one thing we have used that eats up battery power more than other things - when we used it we dropped roughly 30 amps a night (lows were in the mid 50s, older rig so wall/ceiling insulation is not that good - one layer of reflectix on the windows and a sleeping bag between cab and coach).
We drop maybe 10 amps a night with no furnace use (charging devices, lights, regular RV appliances, etc.).
Jane
Nope. (24F two nights ago) I find that turning the furnace off and running a heated mattress pad is a better deal. I have a catalytic heater but haven't used it lately.  It is a tough furnace run to get things warm in the morning. Better to take your shower at night when things are warm. At sunset both battery banks are at 100%. Bedtime FLA is at 85% Li at 100%. Sunrise FLA at 85%, Li at 75% to 85% depending on morning satellite TV use.
Generator initial charge rate is 120 amps bringing Li to 100% and FLA to 90% in less than 30 minutes. Li to FLA DC charger is then turned on and solar turned to Li. By the end of the day both battery banks are at 100% with no more generator. FLA is 225AH and Li is 200AH. To add a compressor fridge I would want another Li battery and charger.
Battery power is no longer a problem. Propane use is not a problem as you can always buy more but I have some ideas to reduce it. Using the heated mattress pad instead of the furnace was a start. I do have reflectix over the two large side windows and one back window of an RB. Also reflectix separates the cab from the coach.
I'm using 60-80 amp/hours, approximatly, overnight. The generator restores about 50 amp/hours in the 30 minute run and solar does the rest during the day. The FLA will be at 100% by evening. If solar hasn't re topped off the Li then an evening generator run is in order, usually about 15 minutes with a charge rate of 80 amps.  It used to be 95 amps. I don't know why the reduction.
Harry 2006RB
