Topic: Body Mount Bolts and Search (Read 239 times) previous topic - next topic
Good Morning; Happy Mothers day to those;
We have a question and a memory problem , do the body mount bolts on 2005 yr FL require regular maintance?  I can see nothing under the coach that looks like it would .   It seems our last LD a 1995 tk I had read they needed tightening ?
Also how does the search feature here work?   I have yet to get anything to work.
Thanks Grumpy
2005 Front Lounge
Re: Body Mount Bolts and Search
Thanks Grumpy
I'll answer the search question. First, please tell me what you have tried and where you have tried it (to search).
By using the "Search" function, under the "Community' column and entering "frame bolts",  nine pages of results were produced .
https://www.lazydazeowners.com/index.php?action=search
Add 'Larry W' or 'Larame SRT", my accidental alter ego that I share with someone else, to see more specialize postings on frame bolt tightening..
Check these links.
Yahoo! Groups
Yahoo! Groups
This question from the OP came at a perfect time.  I have a slight clunk sound when I walk from the kitchen to the entry door.  Other members have suggested checking and tightening frame bolts.
Morning all'
     Here is what I do to try and search;  go to forums, then where it has community above all the forums listings I touch community and under it comes search and I tap it.  nothing, no place to type in a search or anything what am I doing wrong.  I also go to the technical forum and try to repeat and get nothing.   I would think beside where it says in the bar lalzy daze forums and lazy daze tech it would be a space to type body bolts search .   I get nothing I can type in.??
thanks Grumpy
2005 Front Lounge
Hi Esther;  That first is the way it works for me. Under 'community', when the search (and others) come up; click on the 'search' and the search page will come up. Try moving the cursor just slightly and click (or tap) again. Some software requires that the cursor be moved just a bit to prevent double taps.   RonB
    edit:  colddog  has excellent directions and pictures.
