Topic: TM FLOW THRU Flow-Through Adapter - 2 Pack (Read 149 times) previous topic - next topic
I am terrified of having a blowout so I have been looking at these flow thru valves to go with my monitoring system.  I have to much trouble getting to the inside dualies.
These will make it easy to put air in without having to remove the monitor.
Any suggestions are welcome.
Lazy Breeze
Re: TM FLOW THRU Flow-Through Adapter - 2 Pack
What brand of Tire Pressure Monitoring System (TPMS) do you have?
I use the TST 507 system and use  THESE   sending units.
I also use the V2B valve stems on top of them to save the threads....
Alligator V2B valve stem
Take a look at this LDO Thread titled Hubcaps   for information on replacement valves that extend to the outside of the rear duals.
Some think they are about as important as a TPMS  (disclosure- I fall into that group).
Joel
Joel
dog Zeke
