Topic: 2007, 31 foot ceiling paper delamination (Read 185 times) previous topic - next topic
This is happening at several locations of the ceiling mostly at edges, HOW TO FIX?
Thanjs
2007 31 IB
Re: 2007, 31 foot ceiling paper delamination
Thanjs
Are you talking about wrinkling or is it pulling away? Is there a soft spot which would suggest water damage?
If it is just wrinkling which I've seen it can sometimes be fixed with a hairdryer. However, we have a 2006 which had some wrinkling of the paper on the entry door at the edge and for some reason didn't tackle it for years and by then the paper was brittle and it didn't really work. Had the same problem on a popup camper years ago and the hairdryer trick worked well.
Jim
Hi Jim and Gayke
Its wrinkling of the paper, no water damage.  Hoping  someone had same problem with an easy fix, thanks for responce
2007 31 IB
When the heat works it will actually draw up. I assume it shrinks. When we tried it on this one it did not work and I'm guessing it was due to the age of the paper.
Jim
