Topic: hub cap (Read 450 times) previous topic - next topic
hub cap
So in walking around our rig today, I noticed we lost one of the nuts that holds the hub cap on on a rear tire. I don't *think* it was missing last time we checked air in the tires, but who knows. I think that only two of the nuts actually do anything. The missing one has a long stud sticking out the hole, and the hub cap seems loose. I found a funky pliers like tool in the compartment that has the spare tire. It has handles like pliers and the business end forms a hex when closed that seems to fit the nuts. I tried to tighten up the nut 180 degrees from the missing one, but that funky tool really doesn't spin around. The center cap gets in the way. I'll see if I can find a socket that might fit it. Does anyone know where I can buy a replacement and maybe a spare or two to carry with me?
Thanks
Sean
2001 MB
Re: hub cap
Sean,
Here’s an interesting video about installing a nut on a wheel simulator such as those on some LD’s. https://youtu.be/oc5_IiA_6vE
Of course this may only work on the “found” nut. New replacement nuts may be attatched differently.
Re: hub cap
From your description and on a 2001 LD, I'm pretty sure you have the KII wheel simulators from Kaper.  The tool you describe certainly sounds like the tool used for cases like our Bus where a chrome cap fits tightly over the actual wheel lug nuts.  That tools wouldn't be terribly useful on the KII covers.  You should have a metal socket wrench with a T-handle to loosen/tighten the two chrome covered nuts that screw onto those studs.  The other 6 "nuts" are just hollow decorative shells.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Re: hub cap
Thanks
Sean
I posted these some time back. Might help. http://www.lazydazeowners.com/index.php?action=media;sa=album;in=348
Re: hub cap
It is easy to twist off one of the fake nuts and destroy the looks of the wheel cover.
Each cover has two actual nuts, they can be identified by the dimples on the side of their chrome covers.
Re: hub cap
So I went digging around the spare tire and I found the correct tool. I went around and tightened up the rest of the nuts and the driver side rear one was loose on both nuts as well.
Here's a picture of the two tools.
2001 MB
Re: hub cap
I'm glad that you found that you have the correct tool.  I'm not sure what the red handled nut cover tool was doing in an LD.  If you have to drive much, maybe you should remove the cover missing the one nut until you can get a replacement.  I'd also recommend removing the wheel covers anytime you take the coach to a shop for tire and/or wheel service.  Not all (few?) techs at a tire store know how these covers mount and can ruin them in a short time or not remount them properly.
Art
Art and Barbara
Art's blog
Re: hub cap
In case you do lose the hubcap, we have one. A guy rode up to our camp in Quartzsite a few weeks ago asking if we knew anyone who might have lost a "lazy daze hubcap".
Not as such, we replied, but we'd check with our fellow cult members. Turns out he'd been wandering in the desert as one does, and found one. He returned to his camp and fetched it for us. It's been riding around in the back of the pickup ever since.
It's big and shiny. That's all I know.
PS I once sent spouse into Quartzsite in search of small magnets I wanted for some kind of project. No luck, but on his way back he found an entire magnetic door sign for something called Magnashade. We called the number on the sign to report it found, but never heard back. It was too big for the fridge but clung well to the water heater in out last house where it probably still clings.
We finally caught up with the Magnashade guy at the 2017 Escapade in Tucson and ordered a set for the SK-POD. We mentioned finding his sign and he looked at us funny but that was all.
fu
2015TK
Re: hub cap
Is this still available? We lost one last weekend....
Re: hub cap
Cactuscc if that one is not available you can order new one from factory. I lost one last summer, ordered it and put in place. 😊🚐
2 Lazy Bones - Home
Re: hub cap
Supposing an unknowning owner twisted off one of the decorative shells, what is the best way to reattach them? Just supposing.
2006 RB
Re: hub cap
The wheel covers on your 2006 are made by Kaper II; you might want to call them for advice and any parts needed for replacements.
KII WHEEL SIMULATORS
Re: hub cap
Hi Cebuano;  I guess the Facebook meme is "asking for a friend"... If you have the fake nut cover part and it isn't too damaged, you may be able to glue it back into the cover, from the back. Otherwise per Joan.   A few years ago a 2001 was missing one entire simulator and I got the last one from Lazy Daze.  They said they weren't re-stocking that old of a pattern. They might have a 2006 simulator.   RonB
