Topic: A little crack on the fiber glass (Read 174 times) previous topic - next topic
I am thinking of filling it with 5200. Any other suggestion.  What's behind those fiber glass?
2003 RB
Re: A little crack on the fiber glass
Are you able to get a clearer/closer photo? Not enough detail is visible to offer suggestions.
A little fiberglass, a little resin and some wet and dry sandpaper. Good as new.
Fixed a lot of dinged surfboards way back when.
Just for fun I goggled dinged surfboards and there's actually some new easy to use products that might be easier than the old fashioned method but the old ways still the best way.
What To Do About Surfboard Dings
Hi Dave, looks like an impact......maybe a tree branch or very high rock hit. Bondo, for fixing fiberglass is the best. There are also epoxy resin kits already mixed that you just knead, and put in place, smooth down and it will cure in place. good cleaning with a cotton swab ('Q' tip) and some acetone. Be careful with that stuff, it will dissolve lots of things. Sand with really fine grit paper about 600 or better at 1000 grit. A touch up with black, and 'Oxford White' Ford color paint should fix that.
    I use this stuff a lot. You need gloves to mix it. Keep leftovers in refrigerator. (I have a garage 'frig', just drinks)
    jb weld water weld -
   RonB
When repair dings in the front cap, I have used a thicken (with glass beads) plastic epoxy to fill the hole. After curing the patch gets sanded flat and painted with Oxford white . A fiber reinforced Bondo is another choice.
I prefer epoxy, be it fiberglass or plastic epoxy,  it bonds better.
