Topic: Replacing the swamp cooler (Read 216 times) previous topic - next topic
Has anyone successfully installed a roof widow  in place of the swamp cooler?
Is the opening the correct size?
Will the mothership do this or is it a relatively easy fix?
Re: Replacing the swamp cooler
The opening should be 14" X 14", the standard roof vent size.
Do you want a skylight or ?  A clear crank-up vent would provide light and additional ventilation.
Since power should already be present, why not add another Fantastic Fan?
The Mothership do something non-standard?....wishful thinking.
I was considering just a blank window. No crank.
I have a fan-tastic right next to it and one in the bathroom I installed.
You could use one of these, glued and screwed to the roof, to cover the existing hole
Amazon.com: ICON 01817 RV Skylight
I would prefer to use an inexpensive vent cover so the cover can be easily replaced, if damaged.
If a skylight, shown above, is cracked, the whole thing will need to be cut off the roof and replaced.
Plus with a ceiling vent you will get all the trim to clean up the opening. A guy can always use more ventilation.
Hi Ted, Larry. I've had bad luck with Icon products in the past. Too expensive at $56, this one is less expensive, about $38. Note the metal framework, very sun resistant. comes with that noisy fan (you don't need to use it).I bought one of these about a year+ ago, and was very happy with it. I cannibalized it for parts because I didn't want to replace the factory vent entirely. The 'garnish' the plastic part you see from inside needs to be bought separately, about $6.
        HENG'S 14" RV Roof Vent Kit w/ Butyl Tape w/12 Volt Fan Tinted # 74112-C -...
  RonB
  RonB
No question the preferred method would be to use a conventional 14X14 vent.
For $20, it hard to go wrong with this complete kit.
Amazon.com: Heng's 71111-C1G1 Standard Mount Universal Vent - White: Automotive
I mentioned the Ikon cover as an alternative if the OP was set on using a skylight.
I previously saw a great clear see thru vent cover (have to buy the whole thing - inside trim and cover).  Great sunlight but around $250-300.   Made me think of it was worth it as opening our vent without a rain cover gives us a fair amount of sunlight.
One concern about a flat piece of glass - we had a steady strong rain for over a day and had nice size standing pools on the roof. A vent or the window larry showed a link to has a buildup of the frame that would help resist leaks more than just a flat piece of glass sitting in a puddle. It might be with it to confirm if you have any downward sloping at that opening where the weight of the swamp cooler was for years.
Jane
