Topic: Generator volts and Hz way off? (Read 182 times) previous topic - next topic
I tested an outlet in the RV with some lights on.
Hz - 64-65.5 Hz
Volts - 130-133 VAC
Volts at automatic choke lead on carburetor - 30.3 VAC.
I think this is way off.
Is this a generator control board problem?
Re: Generator volts and Hz way off?
It isn't way off. Dial the governor down to 63hz and see what you get. I think the spec is 127 volts at 63hz unloaded.
Harry 2006RB
So just drop the rpm via the the idle control screw?
I don't think it would be the idle control screw but the governor speed control screw. I can't tell you which screw that is. It should be pointed out in the manual. Perhaps someone else knows which one it is.
Harry 2006RB
I found a service manual online.
Just what you said.
Thanks.
"I found a service manual online."
Care to post a link? Others might want to access this.
