Water dripping under rv November 24, 2018, 07:29:13 pm We woke up to drips in 3 spots under rv. No apparent water leaks inside. Could it be coming from outside shower. Can’t quite chase it
Re: Water dripping under rv Reply #1 – November 24, 2018, 08:50:19 pm Quote from: D.C. Frantz - November 24, 2018, 07:29:13 pmWe woke up to drips in 3 spots under rv. No apparent water leaks inside. Could it be coming from outside shower. Can’t quite chase itDid you notice the water spots after running the engine from a cold start? If so, you may have small leaks in your exhaust pipe. Dan
Re: Water dripping under rv Reply #2 – November 24, 2018, 09:00:20 pm It would help to know where the three spots are located in relation to your rig. Are they under the outside shower? The freshwater tank drain valve? Other plumbing items? More specific information would be helpful.
Re: Water dripping under rv Reply #3 – November 25, 2018, 10:14:54 am Quote from: D.C. Frantz - November 24, 2018, 07:29:13 pmWe woke up to drips in 3 spots under rv. No apparent water leaks inside. Could it be coming from outside shower. Can’t quite chase itWater can leak from a pile of different places and reasons. We'd need to know a tad more. Where you running the AC or water heater?
Re: Water dripping under rv Reply #4 – November 25, 2018, 11:50:24 am Spots where water spots may be commonly seen.-Under the refrigerator, the condensate is drained to the ground.-The water heater can 'burp' and release a little water from the pressure relief valve. The PR valves can go bad, leaking continuously .-Water draining from the roof's A/C unit.-Residual moisture released from the cab's engine-powered A/C drain. -Water leaking from the water tank's drain valve.-Anywhere around the perimeter of the body where night time dew drains to the ground.-An engine coolant leak, the fluid smells sweet and has a slightly oily feel.. If you find a coolant leak, please or soak it up and repair immediately, the coolant is fatal to animals that drink it, attracted by the sweet smell and taste.Larry
