Topic: Peeling Clear Coat (Read 302 times) previous topic - next topic
Peeling Clear Coat
I was drying the LD Sunday after washing it and noticed what looked like a bit of moisture under the edge of thin plastic film just above the left/rear end of the awning cover.
Don't know if it's related but it looks like it starts at the primer area that was exposed when the PO replaced the awning.
Any DIY repair recommendations or exprience using a method like this?
Fix Peeling Clear Coat
Or thoughts on using  something like this to stop further peeling until I decide what to do?
3M Clear Paint Protection Film
Rich M.
2006 MB
Re: Peeling Clear Coat
All I can think is keep a good coat of good wax on it.
Hi  Rick,
I would choose your "Fix the Peeling Clear Coat" method.  What they are showing you is how to clean and prep the area for a new clear coat.  The sanding gives your surface a texture that the new clear coat can grip.  The cleaning removes any dust particles that don't allow the new coat a solid surface to grip.  Don't skimp on the prep.  Any paint work depends on how well you did your prep work.  Several thin light coats of the spray clear coat are much better.  It is very easy to get runs from spray cans.  If you don't have plastic to use as mask newspaper works also, all you are doing with it is keeping the over spray from the areas you don't want painted.  Auto suppliers have a tape that is called "Fine Line" it has a thinner edge so you won't have as heavy of a line around your new paint and you may be able to skip the final 2000 grit sanding.  Don't wax over new paint for at least 30 days, that will allow for a complete cure of the new clear coat.
Oh and be sure you have removed all wax from the area, sanding doesn't do it.  Denatured alcohol, or lacquer thinner will do the job.
tlbh2o
Sand Castle (Theresa & Everett) Surfside
01'  26.5 Mid Bath,   2018 31IB
Michigan born and starting to explore the US with my  spouse and our furry friend. Enjoying joining LD group rallies.
Thanks for clarifying the process and tips.
I was initially thinking to buy some time until spring using the tape but now figure better fix it before it gets worse.
It's just a matter of making the time and getting the materials.
The trick for me is leaving the parts store without  something not on the list. ;-)
Rich M.
2006 MB
Not quite sure what we are looking at.  It could have been exposed when shorter awning was installed.
LD sprays the final color paint after the awning has been installed, so there could be exposed primer behind the awning.
LD does not use clear coat paint, instead a two-part polyurethane is paint used that does not require a clear coat.
If you add a clear coat, it will be the wrong color, the primer is not the same color as the Ford Oxford white.
Oxford white is locally available in spray cans, Good chance it will age faster than the factory paint but is should be close to the correct color.
Many auto paint stores custom mix a two-part paint ( known as a 2K paint), in a spray can, that is the right paint chemistry.
This paint needs the applicator to wear protective gear including an organic filter mask. It's best to have the done by a pro, as the paint is hazardous, if inhaled.
Hmmm -  wonder what the thin film like coating is that has flaked off within the outline in the pics If not clear coat?  If zoom in  can make out the edge of the shiny material just inside the outline vs the dull interior where the shiny stuff has peeled and flaked off.
Good to know before I tried the acrylic lacquer clear coat I picked up today.
I did see the 2K paint at Oreilly's but went with what I bought not knowing the difference.
Was planning to practice on a spare Vue door skin I have so thanks for saving me the time.
There is exposed primer behind the awning like you said.
Since instructions say it needs to be applied above 60 degrees and it looks like the awning needs to come off to do the job right, plus your timely advice ..
I now plan to take it to a body shop or two to get their opinion.
Plus I need to get that Vue door skin painted anyway so I can at east get that done and hopefully have the LD paint issue professionally diagnosed as well.
Thanks !!!
Rich M.
2006 MB
"vue door"
Gotta ask....what is that?
Linda B
Green 2021 RB
2022 Ford Maverick toad
