Topic: Water Pump (Read 274 times) previous topic - next topic
Water Pump
Yup it's my and I think this forum's third more fav topic...... behind tires and oil changes.
The problem
It seems when it cold - cold being near freezing - the water pump comes on.   Yup just starts running.     Somewhere around mid day after it warms up - the water pump works normally.
The plan
This morning I plan to re-create the temperature and adjust the by-pass screw.   I'll keep you'all updated.
Re: Water Pump
Did you get a pump with an automatic, anti-freezing feature?
An internal temperature sensor detects near freezing temps and turns the pump on, when it gets too cold, to prevent the formation of ice crystals in the pump, which can lead to cracking of the pump's housing.
Wishing it was April 1.
Re: Water Pump
RE: "... a pump with an automatic, anti-freezing feature?"
Is this a real thing...or like the time I took a wiring class at the local vo-tech's night classes, & a guy told me to get him "a left-handed screwdriver"  :P  (apparently not recognizing that "the girl" in the class--who was probably older than he was--didn't just fall off the manure spreader yesterday  ::) ).
We used to leave the tap running in our laundry room on the farm because there was only an uninsulated crawl space--when we first moved there the neighbors called us when the first freeze happened to tell us to do this; apparently the water line on that end of town was not properly installed, but the city never re-did it--everybody had to keep a drizzle going, because if one person froze up, it could back up the line & affect the next house.   :P
If this is for real, I'd certainly like to swap out the pump I have.  It wouldn't eliminate winterizing, but perhaps give me a little wiggle room if it was colder than the pump liked.
Back in north Missouri tonight, but no calls for frost/freezing weather--quite a difference coming north & getting into Kansas...fall is definitely here, where the leaves & grass in Texas were still quite green.
Lynne
Lynne
Lilly, the 4-Legged Alarm
Re: Water Pump
Is this a real thing...or like the time I took a wiring class at the local vo-tech's night classes, & a guy told me to get him "a left-handed screwdriver"   back up the line & affect the next house.  :P
Lynne
No, it's not real.
I should have waited until April 1st.
Re: Water Pump
No joy --- I checked for the anti-freezing adjustment.   Seems it was removed or was knock off during a drive up I-5.
Re: Water Pump
Well as life would have it the water pump healed itself.  I checked and tighten all the connections.  I'll do random tests between now and weatherizing time.    I will also buy a backup.
BTW is there a good direct  replacement for the Shurflo 4008 waterpump?
Re: Water Pump
Thx, Larry--having matured enough to admit how little I know in this world I've also developed an awareness of my own potential for gullibility   ::) , which is why I appreciate all the discussions on this site & depend "upon the kindness of strangers."  I will file this with the left-handed screwdriver.   ;D
colddog
RE: "Well as life would have it the water pump healed itself."
I do believe in & appreciate the spontaneous regeneration of inanimate objects...in the words of a great philosopher, "I do, I do, I do believe." (The Cowardly Lion in The Wizard of Oz).   ;D
Lynne
Lynne
Re: Water Pump
Well as life would have it the water pump healed itself.   I will also buy a backup.
If the pump did this once, odds are it will happen again.
Carrying a backup is a good idea, it may increase the  life of the old pump by reminding it that it needs to stay in line or it will be gone.
A good replacement for the Shuflow 4008 is another one.
Amazon.com: SHURFLO 4008-101-E65 3.0 Revolution Water Pump: Automotive
