Topic: Replacement for CCI Controls Pre Tell 24 LP Gas Leak Detector? (Read 273 times) previous topic - next topic
I need to replace my original CCI gas leak detector on my 2006 LD. Has someone done this recently and can point me to a replacement model from a another or successor manufacturer to CCI (can’t find CCI in Amazon, but see other brands and models). TIA
Ted
2006 RB
Re: Replacement for CCI Controls Pre Tell 24 LP Gas Leak Detector?
"CCI went out of business some time ago; this is the replacement that I had installed:
Amazon.com: MTI Industries 35-742-BR Safe T Alert 35 Series Dual LP/CO Alarm..."
Just be aware that the center to center screw distance on the replacement may not be exactly the same as the original. Takes a bit of fudging to make it work.   ;)
Does the replacement sensor have the 3 wire leads ?
2004 Mid-Bath
Hi Tank;  Just two wire needed, +12vdc, and ground. Have never seen an RV propane detector with 3.  RonB
    on edit:  Some sensors have three wires, black, red, white. Those all seem to be 110VAC sensors for residential use.
Thank you for the info.
I talked to Lazy Daze and they said the replacement they sell for my 2004 MB is a Safe T Alert 40-442-P.
2004 Mid-Bath
