Topic: Old Satellite Removal  (Read 191 times) previous topic - next topic
I removed a broken, and very large, old satellite dish from the roof of our 02 LD.  The base had been attached with multiple brackets, each having multiple screws.  Each of those screws were long ago heavily sealed.  Since the weight of the base isn't holding the brackets any longer, and the fronts aren't attached to the roof, the front edges of the brackets are free to flex. My concern is whether the air flow may cause issues.  Wondering now if I should somehow seal the brackets or remove them and re-caulk?
2002 30' IB
Re: Old Satellite Removal
Andy Baird removed his. Perhaps he will chime in with tips.
The brackets are almost the same as solar panel brackets.
The sealant looks fine and the hardware tight. The brackets supported a dish for years, without obvious damage.
I woud scrub the surface clean, wipe with solvent and overcoat the edges and recover the screws and nuts, using either Dicor or polyurethane.
And then leave it alone. The floating bracket has little stress on it now.
If you hate the idea of leaving the brackets, the holes can be covered with Eternabond tape, eliminating the screws.
Thanks Larry.
2002 30' IB
