Topic: Ammonia Leak (Read 251 times) previous topic - next topic
Ammonia Leak
Anyone know a method to find the said leak in my fridge?
Re: Ammonia Leak
I know a little about the RV refrigeration and if you are smelling ammonia most likely your frig is  done. They sell new absorption units and can be installed, I know nothing about reliability. In our case the only option was replacement of the frig and most likely yours too. Use caution because the inner workings are under very high pressure and is very flammable.
Re: Ammonia Leak
My understanding is that if there is an ammonia leak - the cooling unit (the metal tubes on the back of the fridge) is toast and needs to be replaced or rebuilt. I don't think it's a serviceable problem. What are you experiencing?
Maybe others have another fix but that's my understanding. I replaced a cooling unit and it was "simple but not easy".
1996 Twin King
Re: Ammonia Leak
The chromate in the system to prevent corrosion  leaves a yellow stain.
Rodney
1988 Mid Bath
Re: Ammonia Leak
Finding the leak is irrelevant. Replacing the cooling unit is the only repair possible.
Re: Ammonia Leak
"...the cooling unit... is toast and needs to be replaced or rebuilt."
Cooling units are not normally 'rebuilt' but they can be replaced. However, if the fridge is an older model it may not be economically wise to replace only the cooling unit... go for the whole box.  ;)
Re: Ammonia Leak
When I was in the market there were companies who would cut out the rusty parts and weld in new and repaint aka rebuild but I bought new from Amish and it was a great decision. Many places require you to provide a core - for whatever purpose they use it.
1996 Twin King
Re: Ammonia Leak
So it would seem I need to hold a funeral. Thanks all.😊
Re: Ammonia Leak
If a refrigerator is not too old, less than ten years old, replacing the cooling unit is a possibility that will cost near half of what a new one would.
You will still have an old box with a lot of plastic becoming more brittle everyday .
A rebuilt kit consist only of the cooling unit, it does not include any new electronics or a valve and burner assembly.
Installation is fairly complicated, beyond the capability of most to do themselves. It feels radical to chop through the refrigerator's insulation  to remove the cooling unit. It takes careful work to have a decent looking repair.
