Topic: EEZ TPMS Customer Service (Read 345 times) previous topic - next topic
This morning one (1) of the TPMS sensors on our LD failed to register with the monitor. This same sensor failed to register a month ago.  So I replaced the battery with a new battery and re-registered the sensor for that tire. About 15 minutes later, the monitor showed all dashes (----) for that tire. We stopped, removed the sensor and checked the tire pressure. TP was good. I replaced the sensor and it registered with the monitor, but once again after about 15 minutes, the sensor reading was all dashes for that tire.
While fueling a while later, I removed and replaced this sensor and once again it registered only to fail again.
I've placed two (2) batteries in this sensor in the last 30 days.
Since our EEZ T515 TPMS is still under warranty, I called EEZ customer service. They suggested I swap batteries with another sensor and see if the problem persists. While opening the problem sensor, the antenna wire was loose. So I called EEZ CS and they suggested I try to solder the wire back into place since a loose antenna wire is not covered in their warranty.
I said this loose wire may have been why the sensor was failing while driving but working while stationary. CS was not interested in helping me.   So I can attempt to solder the antenna wire back into place and hope the sensor works or we can order a new sensor EVEN THOUGH my TPMS system is still under warranty.
On a side note, immediately after we bought this TPMS system, one (1) of the sensors was swollen and EEZ CS said "that's impossible."  After several phone calls over several days, they reluctantly agreed to replace the swollen sensor.
I regret buying this product and I can't recommend it or EEZ's customer service.
Re: EEZ TPMS Customer Service
Ed,
Which tire was the sensor in question mounted on? We have the Tire Minder TM66 and occasionally I will have a front tire sensor fail to send its signal to the monitor. The sensor on the front tires are mounted behind the decorative wheel cover.
Minder Research (Tire Minder Customer Service) recommends the sensor be out from behind the wheel cover. They suggested I call Borg for a new longer valve stem to replace the OEM stem.
I did contact Borg and they shipped me two 3” stems that have a 20 degree bend. So with them and the flow through valves, this should put the sensor out from behind the cover but still out of harms way.
I have yet to install the new stems and haven’t had another “missing signal” since our trip to Zion even though I’ve been to Big Bear since then with no issues.
The Tire Minder systems have a Signal Booster inside the coach that I have mounted above the rear coach window.
Just an FYI. Also Tire Minder has good customer service if contacted directly.
Good luck with your TPMS.
That is disappointing to hear. It is hard for me to understand why the antenna wouldn't be a warranty item. When reading the warranty language I don't see how they exclude it. A loose antenna is a manufacturing defect which their warranty says they cover.
The downside to the company which I understood going in is that they are a small operation headquartered in Quartzsite, AZ.
Over the 4 plus years we have had ours we have had only two warranty issues and they were handled to our satisfaction. Fortunately, ours is out of warranty so I don't have to get a case of heartburn over something like this.
I would ask to speak with the owner of the company. When we bought ours that person was Tom Robertson, tomrobertson@eezrvproducts.com. His cell number at the time was 559-686-5899.
Jim
Either a mfg. defect, or not engineered to be up to the job. Not good either way.
If the solder joint was "cold" -- moved slightly while cooling, or not clean or hot enough when soldered -- it will be mechanically weak, and electrically marginal, especially at RF frequencies and levels.
If you speak with them again, ask if your repair will further void the warranty (for whatever is actually warranted).
Are you good on soldering? If not, I can do it for you.  Standard 60/40 solder with lead will probably not 'take' since it's manufactured with lead-free solder. I can't test it, though, because I'm on the Tire Minder TM77.
If warranty can't be exercised, can you send it back to them for repair? At least they could test it when they're finished.
2000 Front Lounge
This sensor is/was on the passenger side rear.   Margee and I soldered the tiny antenna wire back into place and it seems to be working while stationary.  I'll need to drive the LD to see if our repair actually fixes the sensor.  And if not, we'll just bite the bullet and order a new sensor but it sure rubs me the wrong way.  RV life without a TPMS is just to much of a risk for us.
Thank you Jim.  As you have suggested, I'll send him an email and keep my fingers crossed.  I'll certainly post the results.
Hello Chip.  Customer Service said that there wasn't anything more they could do under the warranty for this sensor.   If soldering failed, their suggestion was to buy a new sensor.  At any rate,  many thanks for your generous offer to help us repair our sensor.   We'll see tomorrow morning if our repair is working when we take the LD for a drive to storage.  If it's working, we'll probably buy an extra sensor as a backup along with a few more batteries.  We've grown accustom to the peace of mind that TPMS brings to our RV experience.
Ed, how much does a new sensor cost?  If nominal, order a new one.
It sounds like you correctly identified the problem and effected a repair.  The question is, will the repair last?
I have had a PressurePro TPMS since November, 2008, when I picked up my unit.  My sensors are sealed, nothing serviceable.  Somewhere around the second year (I can look it up if needed) I had one of my 10 sensors go bad.  I called the PressurePro people, described what was happening, and that I was traveling.  They worked out where I would be in the next several days, and we found a delivery option at a UPS Store in 3 days.  They took my credit card number, but said they would only charge me if the old sensor was not returned.
When I got to the UPS Store, my replacement sensor was there.  I opened the box in the store, took the new one out, put the old one in the box, put the enclosed label on the box and sent it out immediately.  The new sensor got installed and I had no further trouble.  That is good customer service, I think.  After 7 1/2 years, and well out of warranty, the batteries showed signs of failing, by not registering in very cold weather.  Again I made a call to PressurePro to confirm my diagnosis, with which they agreed.  I was due to start traveling in about 6 weeks, so I ordered 10 new sensors, a cost of about $500.  That was 2 1/2 years ago, and I have had no trouble with them since.
Back to your issue - I agree with others that a loose antenna wire should have been covered.  I would reach out for the owner.  If you get no satisfaction there, I would contact the Better Business Bureau and report your poor experience.  I would look for the product on Amazon and do a review that details their poor customer service - what happened, what you did, and their response.  I know you have contacts in other groups and RV forums.  I would publicize your experience there as well.  I believe in publicizing both good and bad service.  If they treat you badly, let the world know.
Ken F in WY
I hate it when you read my mind!  I'm going to order another sensor from Amazon as a backup in case the repaired sensor fails.   And earlier today, I filed several reports with various Consumer Protection Agencies.   I also shared this CS experience on Amazon for the EEZ TMPS that we have now.   This matter has rubbed me the wrong way.  Nevertheless, I'm just going to put this matter behind me.  Life is way too short to waste anymore energy on EEZ.    Thanks Ken for your timely suggestions.
A follow-up post.
After working with EEZ Customer Service to include several problem-solving steps, EEZ agreed that one (1) of our sensors is faulty.  EEZ is shipping a replacement sensor to us.   I owe EEZ a public thank you.  This uphill effort cost me a bit of stress and the lose of a few more hairs but we'll have a spare sensor in case another sensor fails.  (We bought a replacement for a recent trip).  I suppose it was worth it.
