Punctured water line by carpet staple May 19, 2018, 04:17:49 pm We are remodeling a 2004 LD and decided to replace the "not original carpet" out . Of course we had to pull out the numerous staples in the floor. We took a break and came back and found 3 water spots on the floor which was not there before. We had just pulled staples from that location earlier. We think the staples punctured the water line. Question. How do we replace the water lines that run from the hot water heater to the shower. Is there a trick. We are handy with tools. It looks like a tight place to work. Any suggestions will be greatly appreciated .
Re: Punctured water line by carpet staple Reply #1 – May 20, 2018, 01:57:09 pm Will-What model of 2004 LD?MarkFormer owner 1997-8 mid-bath
Re: Punctured water line by carpet staple Reply #2 – May 20, 2018, 06:36:44 pm It's a 2004 mb 26 foot it has pex pipe
Re: Punctured water line by carpet staple Reply #3 – May 20, 2018, 10:31:38 pm Assuming a Mid Bath, the left Access is through the left rear storage compartment or barrel chairs. Right access is through the drawers and or unscrew the pull out sofa guide rail. Remove pullout remove luann covers over water heater.
Re: Punctured water line by carpet staple Reply #4 – May 21, 2018, 01:48:57 pm Thanks for the advice we finally got to both sides replaced the pipes we used press on fitting.
