Topic: Leak from my holding tank (Read 343 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
So, it's clear where it's coming from. Mostly I'm wondering what I'm getting into here. Ya know, before I start unscrewing things.
I haven't used this as a black tank, but this looks original so it's like 40 years old.
The order of operations as I see it:
Drain it, undo the fittings, hope that I can find something that'll work without having to re plumb. This is the outlet, so maybe that won't be such a chore...?
1975 19' RD
Re: Leak from my holding tank
It looks like the threaded fitting has broken free of the tank. It was originally spun-welded into place.
It needs to be welded back into place, using a hot air welder, after a good clean up.
Some RV shops can weld this or possibly a local plastic fabrication shop.
I have not had good, long-term success with adhesives, used on holding tanks.
It could be too old to repair, the plastic may be brittle.
New tanks are available in a variety of sizes, the required fittings can be spun-welded into place.
Thanks! I figured out why I only had the one holding tank, the toilet was self contained, and fairly full. Haha. Oh boy.
  :o  :o
1975 19' RD
They have some incredible water tight tape these days that can even be used underwater. Could be worth trying before an expensive fix.
Cracks on holding tanks can be temporally repaired with Eternabond tape.
Leaking fittings are next to impossible to fix without disassembly and re-glueing or replacement.
None of the speciality epoxies I have tried have held well over any period of time.
Hot air welding or spinning in a new fitting are the suggested ways to repair a leaking fitting.
Larry, I'm not familiar with either of those terms.  Could you clarify what hot air welding and spinning are?
Thermal plastics can be welded with very hot air, using plastic rods to fill gaps and cracks.
Ridgeyard 1600W Hot Air/Hot Gas Plastic Welder Welding Gun with Speed...
Spin welding was already explained.
Hi Greg. Hot air welding is like a hot glue gun on steroids. I worked in a semiconductor fab (back in the day) and on occasion got  to weld polypropylene pieces of sheet together with a hot air welder. Not as fussy as welding metal, but still what I would consider an 'art'. You have to get it right the first time. We had a fancier welder, but I found this on ebay:  1500W Hot Air Torch Plastic Welding Gun Welder Pistol+ 4pcs Speed Nozzle...
   RonB
Thanks for the explanations.  We didn't weld any plastic (thankfully) when I was in the nuclear submarine repair business.  ;)
How about some of that new spray on stuff that's supposed to stop any leaks? Any experience with that? I'm always looking for a bailing wire way to fix things. Comes from being an old gyppo logger I guess. Spent my entire working life making temporary repairs that ended up lasting for years.
I guess anything is worth a try. The spray can sealers are not adhesives, they will not repair the crack, just seal it.
Mechanical motion in the crack will probably cause the sealant to fail after a time.
