Topic: Heater rumbles (Read 179 times) previous topic - next topic
Heater rumbles
I've noticed for a while now an intermittent low pitched rumble when the heater is running. It seems to be getting slightly louder.
Is this normal?
Re: Heater rumbles
Hi Ted. I would expect a worn out bearing in the fan motor, nearest to the fan. Oiling it now would extend the life for a bit, but by the time you hear it, it's already a 'gonner'. A lifetime oil impregnated sintered brass bearing. The lifetime is up when it quits. The bearings aren't replaceable, so you need to look for the complete motor to repair it. RonB
Re: Heater rumbles
Thanks for that diagnosis.
