Topic: window thickness  (Read 341 times) previous topic - next topic
window thickness
What is the thickness of the original double-pane (and now foggy) windows in a 2005 26 1/2' MB? They need the thickness  for an estimate for replacement (with laminated) and I don't have the LD MB in front of me to measure a window. Reading the archives I see anywhere from 3/16" to 7/16" in Forum discussions on window replacement (I imagine there is a mixture because the glass changed a few years before 2005 and people are discussing different year model glass thickness, laminate vs thermal w/airspace, etc.
Thanks,  Steve
Re: window thickness
Hello Steve.  Our LD is not a 2005 and so my measurements wouldn't be of much help.  On the other hand, I'd have to believe that the other original windows in your '05 LD would be the same thickness and manufactured by the same company.  As you probably know, many of the windows in LD are manufactured by Hehr if that helps at all.
In addition, there are several highly recommended RV window companies around the country who can clean up a fogged window less expensively than a replacement.  So that might be something else to consider.  Hope some part of this helpful.
P.S.  Btw, please accept our belated welcome to the LDO Forum.   We look forward to reading about your LD and perhaps an update on the fogged window.
In our '04 it is 1/2".
Ed & Margee / Steve:
Thanks for responding now to our call for help from a month ago - you folks are the only answer we received. The actual answer to our question is moot now since our almost completed deal for that 2005 MB fell apart literally at the last moment.
We responded to a classified ad and we asked many questions. We've been looking for an LD for some years, been in quite a few, and read endless discussions here and the old Forum ( jr member of each) so we are familiar w/many of the issues found in used LDs. The Owner disclosed that the MB had a number of fogged double-pane windows and we were desperately trying to figure cost of replacement and needed the thickness of the glass.
We reached a price adjustment with the owner based on our best guess in replacing all the house windows at a business in Oregon mentioned here in the Forum, sent a down payment, and flew 3,000 miles to perform a final inspection (and call in an expert if indicated) intending to drive it back.
We had also been told that the end cap corner joint at the rear corner of the over-the-cab projection (back of the passenger door) was slightly cracked and was minor and that Vince at the Mother Ship had advised the owner just to calk it w/a certain adhesive which he did.
Besides the expected minor cracked corner cap on the passenger side, on arrival we also discovered that the vertical end caps on each side in the FRONT (back of passenger & driver doors) had lost adhesion to the aluminum from the floorboards up to the over-cab corners to various degrees, and had been caulked by filling in the gaps (up to 1/4"-3/4" wide) between the lifted end caps and the the aluminum walls. One end cap was cracked to it's center a few inches above the floorboard back of the passenger door.
Then we found both of the REAR vertical end caps loose and not adhering in many places from bumper to roof on both sides. In most places a credit card could be inserted in the gaps, many times to the center of the end caps where the corners of the side walls and rear wall would meet. We decided that we couldn't take this kind of work on because health-, age-, and capability-wise we know our limits.
We think the Owner believed that in the FRONT, to keep the rain out, he could simply squeeze a large amount of sealant in the gaps where the end caps pulled away from the coach no matter how wide or how long the gaps and didn't realize how ugly or how short term that fix likely was . We also believe he didn't actually know that the REAR vertical end caps were near falling off as he seemed as shocked as we were to discover this. We sincerely believe he was an honest and honorable man.
In summary, this 3,000 mile trip was our Second VERY serious attempt at buying a Lazy Daze. The first was 1,500 miles also by plane (guess we at least got to see Louisville and Nashville that time).  --- So all told we've put in 4,500 miles in our quest for an LD  (plus many smaller trips) and we are about worn out.
Thanks again --  Steve & Karen,  Allyn, WA
May I suggest that you ask for a complete set of photos, including closeups of possible trouble, areas before you invest in a trip.
If possible, look to later model rigs. After 10 years most LD's will start to have some issues if the owner has not been maintaining it. Beware of older low mileage rigs. They may have been sitting for awhile and not maintained.
Clearly, you have every reason to feel worn out and we certainly wish your LD searches had better results.  If you ever discover a LD in this area of Texas, please know that we'd be open to providing a courtesy inspection.  Others in the LDO neighborhood might be able to help in the same way, which has happened from time to time.  In addition, there are some RV inspection services that are less expensive than the cost of travel.
You live in the land of Bigfoot Class C RVs, which have a strong following even though they've not been manufactured for quite some time.  (Bigfoot still makes travel trailers and truck campers).  While we were searching for our LD, we started to feel worn out too and so we started to expand our Class C search criteria to include Bigfoot and Triple E Class C which were made in Canada. (2009 Triple E 29DBS - CALGARY ,000 | autoTRADER.ca ) .  In my opinion, both of these Class C's are in the same quality category of Lazy Daze.  I hope some of this is helpful.  And best of luck in your search.
Ed & Margee: Thanks for your condolences and your additional advice on seeking a Lazy Daze or a peer in that Class
                          - you are kind and helpful and it is appreciated!
Chris:      Thank you also for your general advice which we had already done in our due diligence.
                 1. Most photos were posted in Forum Classified (2005 MB March, 2018 - Woodbridge, VA) and can be enlarged.
                 2. We did ask for and received closeups of the cracks in the Front corner cap behind the passenger door as well as
                      the main fogged windows which had both been disclosed ahead of time.
                 3.  The cracked cap could be easily sealed as Vince suggested to the Seller. The only fix for the cloudy windows was
                      replacement as agreed by the Seller, Vince, and myself. Since most were cloudy it was agreed that ALL house
                      windows should be replaced since the others would probably fog too and an adjustment to asking price was
                      also agreed to cover this replacement.
                 4. We didn't see that the adhesion of the front vertical end caps had failed and it was not disclosed. The heavy
                      caulking under the loose edges was done AFTER the photo was taken and not disclosed.
                 5. The failure of the Rear end caps adhesion also was not evident in the photos and was not disclosed. In fact I'm
                      sure the Seller was as shocked as us when we discovered this!
                 6. Maybe some of the hardcore experts in the LD Forum, whom I'm so familiar with after years of reading their
                     postings, could have seen these undisclosed problems by closely examining the photos (especially since aware
                     now of the problems). I didn't ask  Forum members to  take a close look at the photos of this MB because I got
                     the impression that advice if the Seller was a Forum member (even if recent membership was solely to have
                     access to posting a classified ad) was to be avoided . I've read many comments by members regarding price,
                     condition, and possible or real problems regarding LDs being sold OUTSIDE the Forum but when I asked , in the
                     past, about a Forum Classified LD my inquiry was not welcome.
                        - Steve
                        - Steve
Steve, I apologize for inferring from your description of problems on this LD that you had not seen photos, or at least closeup photos. The problems seemed so bad that I was assuming they'd show up in closeup photos.
As for posting comments regarding LDOF members who have posted LDs or other items for sale, it is discouraged out of courtesy for our members, regardless of membership timing. We moderators feel that members wishing to gather more information about a for sale item should contact the seller directly, off forum through his/her published email or phone #. This eliminates conversation clutter on the Classified forum.
Comments/discussions regarding for sale LDs posted in other media often can help Lazy Dazy wannabes and are appropriate if constructive and in good taste.
Regarding your "inquiry was not welcome" comment, I don't know what the exact circumstance was and would attempt to address it if you want to contact me off forum with more detail.
I wish you success in your search for a Lazy Daze.
