Topic: Caster and camber ? (Read 184 times) previous topic - next topic
Caster and camber ?
Hi,
I'm researching loose steering and came across this old thread discussing the issue, but with Ford truck.
E350/E450 Handling Problems are caused by too little + CASTER
Does anyone here have experience with this on a Chevy? I am wondering if I should mention this to whatever shop I go to?
Lisa
1991 22' LD Multi-Plan
Re: Caster and camber ?
The biggest handling issues with the Chevy - of that vintage - would be worn steering and suspension parts. These issues should be addressed before alignment. Of top concern, idler arm, Pittman arm, all ball joints, sway bar bushings, shock absorbers. A competent alignment shop can then check alignment.
Thank you!
I guess it was suspension that someone mentioned to me, not the chassis.  I am looking for somewhere to take it....
Lisa
