Topic: Acrylic/Glass Wardrobe Knob (Read 292 times) previous topic - next topic
Last night (being the klutz that I am), I had picked up my dog and as I was turning around whacked the acrylic glass knob off my glass door wardrobe.  I super-glued it back on but it's pretty ugly looking as the base square cracked.
Has anyone ever had this problem?  If so, how would you take off the small square that is glued to the glass to replace the knob with something that doesn't stick so far out as to break off?
This isn't a good photo, but as you know the knob is attached to the mirror on a small square.
Cheryl (a.k.a. Desert Diva)
2002 Honda CR-V
Re: Acrylic/Glass Wardrobe Knob
Our 2002 MB came with those small square handles attached to the wardrobe mirrors and one soon pulled off.  We replaced both sides with larger handles similar to these.  We were very happy with these handles and they never came off.
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Had to do the same replacement.  I used a razor knife to work my way under the remaining plate. Lifting with my fingers but no prying! Even pressure, especially to the side, rather than lifting, patience and heat (hair dryer on low) helped.
I replaced them with a very similar item from Amazon as I recall. For sure me reason we have not had any problem since.
Paul
'92 Mid Bath
Hair dryer and razor blade.
If it's mounted with 3M trim attachment tape, you can saw thru that with dental floss. Once removed, a razor blade will skim off the rest, with acetone cleaning up any adhesive that's left.
Remount with 3M tape (gray with red backer) and allow to 'set' for a day to build adhesive strength, if needed. As long as it's got a similar contact patch, it should work.
2000 Front Lounge
dental floss is a good tip.  Fishing line works too.
Paul
'92 Mid Bath
On our 01 MB, the pull on the left hand wardrobe is starting to separate from the square plate it's connected to. Ours are a similar design to the picture in this thread, but different color. I'm wondering if the factory would still have all the old styles so we could match the one that is still good.
Whats the thoughts on replacing these? Go with factory parts, or something off of amazon?
2001 MB
It's really your choice. I replaced mine with originals; they still are working. Call the Mothership and see if they have your model. I like what Art suggested 2 years ago.
