Topic: Tow Hitch (Read 505 times) previous topic - next topic
Tow Hitch
I tow a 5,000 pound CRV when loaded with my 95TK.
Blue Ox hardware and RVi2 braking system.
My hitch has no bolts.
I assume it's been modified by a previous owner.
I had the hitch inspected and was assured it can handle the load.
Just throwing this out there for those looking to tow.
Re: Tow Hitch
What are you carrying in your CRV that it weighs 5000 lb?
Re: Tow Hitch
For the limited photos you posted, the receiver attachment doesn't look adequate from what I see, the receiver appears to be held by short welds and a coupe pieces of angle iron. It should have a lot more reinforcement and welding. IMO
Did you have a shop inspect it that specializes in hitches?
A better selection of photos would be helpful.
Re: Tow Hitch
I'll take some more pics.
As I recall it was a shop that did specialize in hitches.
We're in Prescott Arizona. I'd like to take it in somewhere but can't find any on Google.
I will add that I've towed this setup over 20,000 miles with no issues but it won't hurt to get it reinspected.
Re: Tow Hitch
There are 5 to 6" welds to the 1/4" plate on either side.
Also s better pic of the angle Iron.
Re: Tow Hitch
"For the limited photos you posted, the receiver attachment doesn't look adequate from what I see..."
First, I am not an expert, but I have seen some good welds and some not so good welds, both acetylene and TIG. These appear to me to be 'tack' welds, and shoddily done at that, something I would not trust. I'd rather see a continuous bead the full length of each contact surface at the very least.   :o
Re: Tow Hitch
We're heading to Flagstaff in a few days.
I'll check in with a hitch place there.
The hitch continues back to a tee where the welds are all continuous.
Re: Tow Hitch
"The hitch continues back to a tee where the welds are all continuous."
I don't have an issue with the construct, it's those welds that caught my attention. A proper weld should flow smoothly, like wavelets on a stream, not clumpy like the bubbles you get when you blow into a straw!  ;)
Re: Tow Hitch
I have to agree, they are not good looking welds, some welds are sitting on top of the metal, an indication of poor penetration.
The heavy rusting isn't encouraging either.
Not saying it will fall apart but they are not professional grade welds, it's more like an amateur home job.
Re: Tow Hitch
As a former Navy welder and NDT (non-destructive testing) inspector, I have to agree with the others that this is not a great looking welding job. A proper stick weld bead should look more like this. This is using 7018 rod, which is commonly used.
At a minimum, I would have all welds cleaned up with a wire brush and closely inspected. Better yet, you may want to have the welds cut out and redone by a good hitch shop that employs a good welder.
Re: Tow Hitch
Thanks for all the advice.
When I get to Flagstaff I'll hit up a welding shop to beef up the hitch.
Re: Tow Hitch
Update...
Found a welder in Sedona, AZ.
Ed's Welding and Fabrication Ed's Welding and Fabrication/ Metal Sales/Trailer Repair/Metal Art/Railing/Ga...
We crawled under for an inspection of the hitch. He said while the stick welds "aren't pretty" they are sound with good penetration. He mentioned the overall hitch structure was more than adequate for my towing. He said it's a bit "overbuilt" in fact.
Ed has 40 years experience and modifies many tow hitches per year.
I feel better now.
