Topic: Cab curtain tape (Read 483 times) previous topic - next topic
Cab curtain tape
Hi
I think there was discussion on this topic before. Has anyone replaced the tape that is sewn to the curtain with the little square thingees that slide in the metal track on rv cab curtain? The cheesy plastic tape is breaking down already even though the LD is only 4 yrs old!  Looking for sturdy fabric tape.  Any ideas?
Corky
24 TK 2013
2013 TK
Re: Cab curtain tape
You might try Curtain-Tracks.
We replaced the original cab curtain several years ago with ones equipped with glide tape.
The glide tape was plastic, with the guides heat sealed to the track.
Within a couple years, the plastic started ripping apart, releasing the guides
I bought several yards of fabric glide tape from Curtain-tracks.com and replace the center sections the curtain, where the slides had broken off
It was not an easy job dealing with the pleats. I do admit I'm not a great sewing but I can stick things together.
My light weight Singer had a hard time dealing with thickness of the curtain and tape.
Hi Larry and Andy,
Thanks for the suggestion of curtain-tracks.com.  I found the stronger material tape and am ordering it.  As Larry says, it will probably be hard to sew it but the plastic tape is falling apart already so not much choice in the matter.
 I appreciate your help as always!
Corky
24 TK 2013
2013 TK
I want to thank everyone who contributed to this thread. I was able to refurbish my cab curtains. The original plastic tape had cracked and many of the square plastic sliders were no longer attached to the curtains. I ordered the fabric tape from curtain-tracks.com, bought a Brother sewing machine (thanks, Ken Fears, that machine is definitely able to handle some REALLY thick layers of fabric!), and sewed the new fabric tape to the old curtains. Success!
Jan Forseth
2007 27' Midbath named Footloose
Yes, that's the type that I purchased and used. Be aware that the stuff is very hard to "glide" on the tracks. I'm hoping it will loosen up with wear. (A reference to the British TV series, "Are You Being Served?")  :D
Jan Forseth
I suppose a person could sand a bit of material off the glides or install one (1) of that company's tracks designed for this product.  We have just one (1) broken tab that we're repairing.  I've bookmarked this topic and the website because I can see our curtain's future.
I thought about using a Dremel to light work on the glides. That's good news that you have only one broken tab at this point.
Jan Forseth
