Topic: Generator access?? (Read 237 times) previous topic - next topic
Generator access??
I want to change my spark plugs and see no way of getting to the second one in the back.
Does the bottom skid plate act also as a support plate for the generator?
If not can I remove it to gain access?
Re: Generator access??
If it is a Onan micro 4000 it only has one plug.
Lynn and Lori
I have an Emerald Plus..and yes, the back spark plus is a bear to get to..have to reach up and over to reach it, not easy as you're half under the rig with limited mobility..I've had it done when getting other things serviced by people with a lift or with a pit underneath At 12:12 PM 2/7/2018, you wrote:
If it is a Onan 4000 it only has one plug. > 2002 Lazy Daze 26.5 mid bath
Lynn and Lori
You can reply to this email and have it posted as a topic reply.
LDO Links:
index.php?action=notifyboard;board=2.0 Regards, The Lazy Daze Owners Team
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Gini Free and Junah, canine xtrodinaire "CHERRYOTTE" our litte red home on wheels "Growing old is mandatory. Growing wise is optional."
I have not changed the Emerald spark plugs on my '88 MB, but would a 3/8" drive spark plug deep socket with an external hex drive and an open end wrench do the rear spark plug removal trick?  I have one in my Sears Companion socket set from 50 years past.  Larry probably knows this answer!
Rodney
1988 Mid Bath
On second look mine is a 4000 "Emerald Plus".
I think it may have 2 plugs.
If it does I have about 1" of head room to reach back there. No way will that work.
Yep two plugs on those Emeralds.
Lynn and Lori
i just did mine a few months ago, i thought i remembered an access hole on the backside of the box it's in, no? don't remember it being very hard.
1999 MB
Looks like I will be in for a challenge.  In my '88 MB that access is under the plywood dinette bench hump!
Rodney
1988 Mid Bath
