Topic: Removing the Hot Water Heater Pressure Relief Valve (Read 343 times) previous topic - next topic
I did this years ago. It was easy. Not so now.
There is probably a special wrench designed for the purpose?
If I remove the shroud to the left of the valve I might get a small pipe wrench on it.
Or is there a simple way.
Just want to soak it in vinegar, it's been in there for several years,
Re: Removing the Hot Water Heater Pressure Relief Valve
Don ... mine was a bit tight when I removed it last year.  I just used a bigger wrench and it broke loose.   If it's really stuck, I might consider a shot of penetrating oil.  And I didn't need to remove the shroud.  The PRVs are rather inexpensive so you might consider a new one.
Is the valve directly screwed into the hot water tank?
Don,
I agree with Ed & Margee.  If you're going to the trouble to remove the valve from the water heater, replacing it is a wise decision IMHO.
Bill
2003 -- 23' FL
Camco sells a tool for removing and replacing the P&T valve:
Camco P&T Valve Removal Tool on Amazon
For a one-time use, it's pricey. Better to borrow one from your friend who has every tool- you have afriend like that, yes?
Mark
Former owner, 1997-8 mid-bath
Mark, that is what my service guy used when he did mine a year ago.  It was crudded up and had a slow leak.  He used a 24" breaker bar with a 2 foot pipe extension to break it free.
Ken F in NM
Ken F in NM
Ken-
Amazing what a little aluminum/brass interaction can do. I used the tool, but a regular wrench. I suspect it came out easier because the water heater was only a few years old.
I'd offer to give Don the Camco tool I bought (as I shouldn't need it for a while), but it's at home and I'm not.
Mark
Not having the dedicated tool, I use a 12' crescent wrench opened up and slipped over the end of the relief, so the wrench is sticking outward. A extra long screwdriver is inserted through the hole in the crescent wrench's handle. It's used with a breaker bar to loosen the valve..
Crescent 12 in. Adjustable Wrench-AC212VS - The Home Depot
Having trouble seeing this. Is the wrench handle in line with the valve? 90 degrees to the rig?
Picture?
Merry Christmas
does the atwood take the 3/4"(90028) or the 1/2"(91604) valve?
1999 MB
I'm looking at my receipt and it looks like ours was a 3/4" valve, model number is 10473.
Hope this helps.
yep, that's the camco # for 3/4". thanks
fyi all 3 of these part numbers are 150psi valves.
Atwood also has a 75psi, 3/4" RV that is p/n 92647...
1999 MB
