Topic: double sink cleaning (Read 226 times) previous topic - next topic
In the very dim conners of my mind I seem to remember a thread about cleaning and bringing back the whiteness of the kitchen sinks.     If someone could point in the the correct direction I'd be very happy.
Re: double sink cleaning
Clorox cleaner and bleach spray works great to whiten a stained sink.
I have cleaned up many, to the surprise of their owners .
Spray the entire sink and keep  it wet fora period of time. Respray, to keep it moist for an hour or more.
Then rinse and wipe with a sponge.   Do have an abundance of air fresh air or leave it alone , while it does its work.
Amazon.com: Clorox Clean-Up with Bleach, 32 fl oz Trigger Spray Bottle (Pack...
Soft Scrub, with bleach also works well but the spray bleach is much easier to use.
It is my preferred chemical for cleaning the walls of the shower..
Amazon.com: Soft Scrub Soft Scrub Cleanser with Bleach - 36 oz - 2 pk:...
Thanks Larry! I will have to give it a try. My 2002 sink doesn't look as good as I would like. And I have been thinking about taking on the task of replacing it.
Lynn and Lori
Try cleaning it first, removing a Factory sink is a major project,.
LD glues the sink in with globs of polyurethane, making it very resistant to removal.
Damage to the surround counter is possible, so it must be removed carefully.
I cover the counter top, around the sink, with many layers of masking or duct tape, for protection while the sink is cut out.
Use a vibratory tool with a sharp chisel blade and force the blade under the sink's lip.  After multiple trips around the sink, you should be able to force it up and out...eventually.
it's one of my least favorite projects.
FYI, before starting, make sure the exact replacement is still available.
Many have tried to find and install a stainless steel sink, I have made a couple of attempts.
The problem is find a close replacement with the same sink depth, so the drain plumbing still has the right amount of "drop" or slop, for proper drainage. No one has found the right sink yet, so stick with the a stock replacement.
I trick I tried (not mine) for a stubborn kitchen sink stain (rust) was to set a half lemon on the stain overnight. Completely gone by morning, gleaming white again.
