Replacing Blue Ox Rubber Boots 8 years ago I am replacing the boots on our Aventa LX bar. After cleaning the bars they recommend lithium grease be applied. I happen to have on hand spray on lithium grease. Any ideas if that is OK or not?Jim
Re: Replacing Blue Ox Rubber Boots Reply #1 – 8 years ago Quote from: Jim & Gayle - 8 years agoI am replacing the boots on our Aventa LX bar. After cleaning the bars they recommend lithium grease be applied. I happen to have on hand spray on lithium grease. Any ideas if that is OK or not?Use the spray.Larry 1 Likes Liked by: Jim & Gayle
Follow-ups Big Foot Levelers Re: Replacing Blue Ox Rubber Boots Reply #2 – 8 years ago Got around to replacing the boots and it's relatively easy until you try and get the new boots on. You remove the knuckle which is attached by the one bolt, spray the inside of the boot with silicone and then good luck. After breaking a couple of thumbnails I got it about an inch down.Called blue ox and the support guy said he had used pliers but you have to be careful not to damage the boot. I recalled I had slip joint pliers with rubber protection on the jaws and that made it much easier. Once you get the first segment over it is easier but I had to lean my upper body into it to force it down.Maybe someone else here has found a simpler way but thought I would throw this out there.Jim
Re: Replacing Blue Ox Rubber Boots Reply #3 – 8 years ago Ken Fears and I replaced my rubber boots one time. We used a spray soapy solution, and that really helped slip it over the knuckle. We didn't actually have to remove the knuckle.Glad you've got yours figured out.
