Topic: Dismantling Propane Alarm (Read 269 times) previous topic - next topic
Quick!  Before I go batty (more batty)!
Not dryer sheets, not heat, not perfume, not flatulence ... but something is setting my propane alarm to incessant beeping.  Although not quite 4 years old, it may be time for a replacement.  In the meantime...I've pulled the in-line fuse and the #8 in the box -- no joy.
What's the next step for disabling this thing?
Thanks for all ideas!
2003 RB
Re: Dismantling Propane Alarm
Could a propane leak be setting it off?  :o
If your house battery charge is low the alarm will go off to let you know there was a power interruption.  For example mine would regularly go off when the fans kicked on very late at night, or when the electric step went down.  This happened to me when the original house batteries were near the end of their life.
John
Previously: 2007 Mid Bath
You might try vacuuming it or blowing it out.  Could be dust setting it off.  It should last longer than 4 years.
Hmmm...John,  Although I haven't had that particular experience, I'll file it under "good to know, just in case."  Thanks -- now please see next message.  (Sure do appreciate you "answering" my call.)
2003 RB
All is well...neighbor claims he heard me cursing and saved the day!!!
Thanks for your suggestions -- now I'm going to keep a close eye on those dust bunnies!
Everyone go back to whatever you were doing an hour ago!
2003 RB
So what was the cure, Lorna?
