Topic: Inverter outlet (Read 205 times) previous topic - next topic
Inverter outlet
New to Lazy Daze.  The outlet from my inverter has no power.  Cannot find a breaker or fuse for it.  Is there one somewhere.
2003 26.5'
Re: Inverter outlet
Kenny, while you wait for more expert responders than I, can you tell us what year and model LD you have?
Paul
'92 Mid Bath
Re: Inverter outlet
What model and year LD do you have? If it is the 30' IB or TB then the inverter is under the fridge. You need to pull out the drawers under the fridge to access it. The reset button is on the left side facing the entry. They were using a Xantrex XS400 watt inverter in our 06. If that is your model this is a link to the manual. http://www.xantrex.com/documents/Power-Inverters/XS400/XS400_Owner_Guide(975-0054-01-01_Rev-B).pdf
Jim
Re: Inverter outlet
Jim
26.5'  year 2003.
2003 26.5'
Re: Inverter outlet
Fixed the problem.  Corrosion on the battery terminal.
2003 26.5'
