24 Twin/King bed question August 24, 2017, 09:51:38 am Just wondering if the dinette to bed in the 24' twin is like a jack knife bed - pulling up and out? Folks seem to like the cushioning in these beds.Annette
Re: 24 Twin/King bed question Reply #1 – August 24, 2017, 09:54:20 am Quote from: Gmnetsie - August 24, 2017, 09:51:38 amJust wondering if the dinette to bed in the 24' twin is like a jack knife bed - pulling up and out? Folks seem to like the cushioning in these beds.AnnetteNo, it is not a jack knife style.You remove the seat cushion then slide the bottom section out.
Re: 24 Twin/King bed question Reply #2 – August 24, 2017, 09:58:12 am Thanks for the response - been wondering about that bed.Annette
Re: 24 Twin/King bed question Reply #3 – August 24, 2017, 11:47:46 am "You remove the seat cushion then slide the bottom section out."----I describe the TK or MB couch>bed change procedure as this:Remove the back cushion. Take down the support panel (optional if one doesn't need all the space) and fold it against the wall. Lift up the front of the couch frame (mine has straps; since LD is slow to make changes, the set-up is likely still the same.) and pull the base into the aisle. Lay the back cushion into the space between the bottom cushion and the wall. Repeat the procedure on the other side if one wants the whole back end as a bed. 1 Likes
Re: 24 Twin/King bed question Reply #4 – August 24, 2017, 01:00:00 pm Very good explaination. I haven't read any comments on this topic so really appreciate any/all discussion of this bed issue.Annette
Re: 24 Twin/King bed question Reply #5 – August 24, 2017, 03:59:04 pm My dog insists on the TK arrangement in the Mid Bath. "You must set up the King bed!" Those two legged slaves(Humans) get the walls and she gets the middle! All 85 pounds of her. 2 Likes
Re: 24 Twin/King bed question Reply #6 – August 24, 2017, 05:06:50 pm That sounds like my 1 and 3 year olds 1 Likes
