Topic: Re: How to repair a leaking city water connection valve instead of repla (Read 197 times) previous topic - next topic - Topic derived from How to repair a leaki...
i've been prepping this one too, i found this image of the valve... i see the backside of the brass fitting behind my toilet in my MB. no one has a pic of how the brass fitting screws onto the 3 hole plate do they? the inside is fairly blind.
1999 MB
Re: Re: How to repair a leaking city water connection valve instead of repla
Here ya go. I brain-effed my winterization last fall and had to apply this fix. There is also a good description of the fix at the Companion. I did not remove the entire fixture and instead inserted the parts. You need a helper to hold the "golf tee" in while you attach the spring and ring.
PS - I bought a donor valve instead of putting in the old pieces. These valves differ so if you go this route take your golf tee to CW and compare the sizes of the valves there. There were a couple choices at my CW and the large end of the golf tee were of different sizes.
https://youtu.be/Vy5ISONusNk
split out this new discussion from a 5 year old archive topic
Just need to take a moment to thank mcnugget and huskerblue.  As mentioned many times, a picture/video is worth a 1000 words.  This post is bookmark worthy IMO.  Thanks for the post.
P.S.  What was the word for the Double Letter Score ... water?
Good video. My problem is not the CW leaking but makes an awful high pitched sound when I turn on any inside faucets, and it doesn't matter if I'm hooked up or not, and according to Vince that's what he says is the problem and he doesn't have a fix. Can anyone help me with a solution for those? Thanks in advance if you do.
2014 ?
