Topic: Both 12V outlets don't work - separate issues (Read 139 times) previous topic - next topic
Hi, regarding our 94 RB:
I have searched this site, the LD owners manual and the Econoline repair manual extensively, with no success so far:
#1 TV outlet just died, but it is still getting power at the outlet as the antenna boost lite turns on. We use a 140w inverter to charge computers and phones from it.  Also just use a phone charger, that is not getting power wither. All known fuses are fine and everything else 12v works in the rig.   I'm guessing that a circuit has blown on the antenna boost board (as it's all one unit) and I need a new one (if still available on such an old rig?).  Other ideas?
#2 The cigarette lighter in dash has never worked in the few years we have had the rig.  Fuses under the dash are fine.  Checked a few inline fuses under the hood and they are fine also.   Any Ideas?   The windshield fluid pump has never run either - perhaps they are on the same fuse some where?
Thanks in advance for any insight you might provide!
Pete
Pete
1994 RB
Re: Both 12V outlets don't work - separate issues
The cigarette lighter on our 2009 was not working when we bought our LD from the original owners.   After checking as you did, I found the wire connection behind the dash and the socket were not connected.  Hope this helps.
I have a later version (2000) and it has two "cigarette lighter" outlets on the dash.  One worked, one didn't.  Found that the fuse was also protecting the OBD-II power, because it didn't work either.  Don't recall which specific fuse it was, but it was either under hood or by pedals -- not hidden elsewhere.  It was in the Haynes manual you can get at auto parts stores, as well as Ford owner's manual.
Chip
2000 Front Lounge
