Topic: Has anyone tried the Kojack Leveller?  (Read 156 times) previous topic - next topic
It looks so simple and quick compared with using blocks.
Re: Has anyone tried the Kojack Leveller?
The Kojack leveler is made to level travel trailers
Each Kojack leveler is rated at 1000kg or 2200-lbs.  They could be used on the front wheels but will be right at the limited of their capacity, which will wear them quickly.. They are not strong enough to lift the rear corners.
The front end of your LD weighs over 4000-lbs, the rear 9000-lbs
Kojack | Support | Purple Line
