Topic: roof moss (Read 612 times) previous topic - next topic
roof moss
Hello ,
With wet winter in Ca and spring in Or, moss is starting to grow on roof.  Seems to like rough texture of roof paint.
Anyone have a good method to remove it ? Dish cleaning soap works, but requires a bit of rubbing.
2013 31' IB
Re: roof moss
Could try spraying with RoundUp, or white vinegar for more eco-friendly.
Re: roof moss
I would try a mixture of Jomax and Clorox bleach.  It works great on mold/mildew growing on vinyl siding in south Louisiana.
2004 26.5 MB
Re: roof moss
JMHO, but I wouldn't use Clorox, alone or in combination with anything else (Jomax MSDS: http://www.homedepot.com/catalog/pdfImages/48/48ab1a52-1580-4733-8397-b0067c293b25.pdf), on any surfaces of the motorhome.
Scrubbing with a mixture of Simple Green, very warm water, and a stiff brush (hose off the roof after scrubbing it) will remove moss/algae.
YMMV, of course.
Re: roof moss
Here in the great northwest it is a continual battle. Sink sulfate, sink chloride are popular moss control compounds that can have negative impact on fish, invertebrates and other plants. Bleach is effective,but also can cause corrosion issues elsewhere.
Agitation with mild soap is a good place to start. Up on the roof, hands and knees with a medium stiff brush. Moss has amazing holding power- determination is required to overcome it.
In our case we were able to remove all moss, but black stains remain that nothing will touch.
Paul
'92 Mid Bath
Re: roof moss
As a PNW owner it, moss and black 'stuff'  is a continual battle.   For the most part I use a mild auto wash type soap and water with a medium soft bush  while my hands and knees.     I've in the past used various moss and black stuff removers but have found soap and water with a bit of hand and arm work is the best and easiest path.
Re: roof moss
As another PNW owner I found that GEL-GLOSS rv cleaner wax does a great job getting the black streaks off.
Lynn and Lori
Re: roof moss
The black stains I battle are what the moss on the roof has left behind where it was anchored.  The usual RV black streaks on the sides streaks are never a problem. A well polished and sealed rig will allow them to be wiped away with normal car washing procedures. And a clean roof means they rarely appear, though Lake Newton on the top of any Lazy Daze seems to guarantee that a clean roof is a very temporary condition!
Paul
'92 Mid Bath
Re: roof moss
Paul
"Sink sulfate, sink chloride are popular..."
I think I'd like 'Zinc' rather more than 'Sink' if it's all the same to you!   :D
Re: roof moss
Yep, sink. I mean sink! No, darn it, ZINC
Now shut up autocorrect.
Paul
'92 Mid Bath
Re: roof moss
RMR-86. Rapid mold remover. Bought on Amazon. Worked for me.
Re: roof moss
May I suggest that when you store it, that you elevate the wheels so that water can not remain on the roof. If the storage location is flat, it may take 10 inches to ensure it drains. This will require several ramp blocks to drive the rig up on. Front or rear, does not matter, except you will need less wood for the front - half the width of the rear.
PS Water will find it's way in if allowed to pool. Maybe not this year, but it will happen.
Re: roof moss
Steve S. said, "I think I'd like 'Zinc' rather more than 'Sink' if it's all the same to you!"
My Inner stickler thanks you...though I didn't know what either product was.
Lynne
Lynne
Lilly, the 4-Legged Alarm
Re: roof moss
A version of quaternary ammonia, relatively safe but can cause eye and skin irritation. In sufficient dosage it is poisonous, so keep the small critters away when using. A good product, but IMO mild soap like Simple Green and agitation give equivalent results with less impact on surroundings.
Paul
'92 Mid Bath
Re: roof moss
Simple Green. Spray on & let sit for about 15 minutes. Scrub. Rinse & repeat until it's gone. Rinse very well when done. I too live in western WA, whete evrrything turns green. Simple Green is our go-to for getting the winter stains off.
Lori Y
2011 24FL
Lori Y
2011 24FL
Re: roof moss
Glen, you have heard right- when not used according to directions Simple Green will corrode aluminum. This from their web Q&A:
" ▶ Aluminum — Is it safe to use Simple Green All-Purpose Cleaner on aluminum?
When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green Industrial Cleaner & Degreaser, and Simple Green Pressure Washer Concentrates have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
Simple Green has also developed break-through water based cleaners that are safe for use on metals, plastics, rubber and high tech alloys. Extreme Simple Green Aircraft & Precision Cleaner, Pro Series Simple Green Automotive Cleaner, and Simple Green Pro HD are available on both the industrial and retail markets, respectively. These products were initially developed for the aircraft industry and extensive testing shows that they are safe and effective on a variety of metals and other sensitive surfaces even in the most extreme circumstances.
Simple Green Stainless Steel One Step Cleaner & Polish is another option for cleaning polished aluminum. This product is designed for light duty metal cleaning and polishing."
Of course, vinegar, dish soap, laundry soap, bleach and most detergents are either acidic or alkaline, so potentially harmful. ALWAYS read and follow directions, more is not always better.  Agitation is your cleaning partner. That means exercise.
I like to rinse powerful cleaners as aggressively as I scrub, agitating while flowing water over the area.  It is good the moss growth zone is usually not a water conservation zone.
Paul
'92 Mid Bath
Re: roof moss
There are some advantages living in a Mediterranean climate.
Moss is something we grow in pots, on a sheltered, shaded patio, drip irrigated daily .
Growing it on the roof of the LD would be too much work.
A rolling LD gathers no moss
Re: roof moss
I just finished doing mine with my long handled carwash brush.  I wetted it down with water and carwash soap and then found that if I flipped the brush to the hard plastic side that most of the moss would come off that way.  Then finish with the brush side and rinse.  A strong stream of water also worked on some of the hard to reach places.  I didn't try an electric pressure washer-not sure if that would be too much and remove the paint too.?
2003 30' IB
Re: roof moss
Living in the pacific NW, we deal with lots of moss.  Wet and Forget works great for the green stuff, not so good for the black stuff, but it is pretty pricey.  I've found that brushing a mixture of  Oxi-Clean with dish soap and water works wonders on at least the green stuff, but, as Joan always says, YMMV.
Rich ex 2000 MB - Birch Bay, WA
Re: roof moss
Bob, you're right. I would not recommend using high pressure to remove moss.  It is so well anchored that the pressure required to remove the moss can be damaging.
I wonder if Larry has had success with his removal?
Paul
'92 Mid Bath
