Topic: 12v to generator? (Read 185 times) previous topic - next topic
12v to generator?
Where do i shut off the 12v lead to the generator? It goes up into the floor of the coach,  but I see no fuses or breakers in the coach panel.  I need to disconnect it.
Thanks
1999 MB
Re: 12v to generator?
First, you would need to tell people you have a '99 Mid bath. If you have a battery switch between the batteries in the battery compartment then that is the place. I have an RB so beyond that, I don't know.
Harry 2006RB
McNugget,
My '88 MB has battery on the right side.  I do not have a disconnect switch. It's wires (4 red 2 black)exit upper rear of battery box into coach and rear dinette bench, go under carpet, exit the floor near chassis/ front of battery box to the two resetting circuit breakers mounted on the bottom of the floor between the generator and battery box.  A ground goes to the chassis here also.  My only disconnect is to remove the two negative battery cable at the right rear negative post.
2 red wires to double resetting breaker set, ? Isolator?
1 red to a single resetting breaker, ? Converter?
1red must go to generator ?
See the picture in avatar photo, you can spot Battery and generator doors.
Rodney
1988 Mid Bath
So,  yes,  99 mid bath.  I was kinda struggling with my phone and grease covered hands.  In the end I wound up pulling the negative on the coach batteries and the lead still had voltage at the Genny,  so I left it connected and just dropped the generator 4 inches.  That was enough to change out the carburetor.  That is one tight job....  And apparently new carbs for that emerald are on national backorder till at least fall.
Thanks all
1999 MB
