Topic: Window Locks (Read 370 times) previous topic - next topic
Window Locks
Another window lock has broken  :( and the last post with the part # was 10 years ago.  It says Part # 110-241 from Hehr International.  Is there any more recent information on these?  And is Hehr International the best place to get them?  Am I the only one that has window locks that break off every few years?  Must be the vicious California sun  :'(  Any info on these would be appreciated.   ~~~~Rose
2004 MB
Re: Window Locks
What year is your rig? This lock fits the double-pane windows. You could also try e-bay, the mothership.
Re: Window Locks
What year and what window?
Re: Window Locks
2004 MB The locks that are on the sliding windows....they flip up and down.  There are 7 of them in the MB.
2004 MB
Re: Window Locks
If you find a place to get them, let me know.  I have the same issue with broken window locks on my 2002 MB.
Glenn & Joan Lambert
Redford, MI
2017 27' Mid-Bath
Re: Window Locks
I may have some info in my LD which I will have at home tomorrow. If so, I will report it.
Re: Window Locks
Broke one a couple years ago on my 04. I just bought the one at Camping World. It looks different but it works fine. Sooo, I bought another as a spare. 👍🏻
Re: Window Locks
I had several break in the last couple years on my 2007 MB. They don't make the original ones anymore and the RV store I went to replaced the first broken one with the newer model of Hehr double pane window latches. I then went online to amazon and bought some more to have them on hand as the others break. They are also available at camping world and probably other supply stores
They are a little different then the originals but work fine except you have to be sure they are latched tightly when you close the blinds or the latch handle will catch
Stephany Smith
2007 MB
2007 MB
Re: Window Locks
Stephany Smith
2007 MB
Stephany, can you provide a link to those latches?
Re: Window Locks
bus parts
Here is the Hehr part # 110-241
2002 27" RB
Re: Window Locks
Here is the part I purchased at CW. Again, the latch mechanism is a little different as it "sticks out" when in the open position but again, it works on my double pane 04 window. There is a single pane latch at CW too that may work on older models.
It's nice to have a CW about two miles from Ruby's storage as I can experiment and if something doesn't fit I can take it right back.
Dave
Hehr Window Latch - Double Pane - RV Designer H697 - Interior Hardware -...
Re: Window Locks
amazon link for the replacement latches I bought and have been using without problems for several years
RV Designer H697 3" x 5" x 1.5" Hehr Style Double Pane Window Latch
Amazon.com: RV Designer H697 3" x 5" x 1.5" Hehr Style Double Pane Window...
There are less expensive ones on amazon that are not prime shipping
2007 MB
Re: Window Locks
     I just ordered two more for my 2005 27.5 MB.  Lazy Daze mothership had  them for $5.00 a piece.  Shipping $2.69 and handling $3.50 = $16.19.  Check only.
1994 22 LD, 2005 Midbath, 2016 Midbath
Re: Window Locks
Of the locks linked/shown/described in messages in this thread, which did you order from LD? The locks on later models have changed through the years.
Re: Window Locks
Huskerblue's link to the Hehr double paned lock, H697.
Thanks. I believe those are the newer "sweep" latches. On my '02, I have Prime-Line Products F 2612 Sliding Window Sash Lock, Right and Left Hand,....
