Topic: White streaks under water heater compartment (Read 188 times) previous topic - next topic
This is probably not a unique problem, but after perusal of the library of solutions, I didn't really come up with anything useful for a solution.  We have some white streaks from where the water heater "spit up" along the outside of our grey 2005 RB.  Unsightly!
Vinegar has not been helpful.
Any suggestions?
   Virtual hugs,
   Judie  <-- Sierra Vista, Arizona
   Adventures of Dorrie Anne | Photographing the West
   Today:  Awaiting a Giant Snake
Re: White streaks under water heater compartment
Judie, if straight white vinegar didn't work, you might try CLR or Lime Away, but I'd sure do a pre-test of either/both on an inconspicuous painted area to make sure that the stain removal didn't take the paint with it!  :o
I have found that a regularly scheduled 'burping' of the hot water tank to reestablish the air bubble will reduce the weeping that you have experienced from the pressure relief valve.   ;)
And, if not connected to city water, if you will turn off the water pump and leave a faucet open before you light the water heater you should also see a reduction of that weeping.  ::)
CLR works well to remove hard water marks.
Our LD develops water spots around the fresh water fill door, from water sloshing up the vent and out.
