Topic: edging repair w/o screws... (Read 242 times) previous topic - next topic
When the vertical corner flashing behind the driver's door had started coming loose from the front side, where I wouldn't want to mar the surface by adding screws to hold while the polyurethane sealant dries (several days), and did not want to leave the rig unlocked, I devised this simple method of applying pressure to the flashing. I used thin, flexible strips of hardwood, and a piece of nylon strap knotted, with the door closed and locked on it. Sufficient pressure is thus applied to compress the flashing to the side:
Re: edging repair w/o screws...
Clever, Steve! I just "marred" my front edge cap repair with SS screws.  ;)
"...flexible strips of hardwood, and a piece of nylon strap knotted..."
Now that's what I'd call outside the box thinking, doubt if I'd ever imagineer something like that!   :o
Many times the caps can be wedged into position, during the adhesive cure, but there are situations where the caps cannot be forced or clamped into position without using screws.
If the cap does not sit correctly or clamped  screws are needed to pull it into position.
During construction, when LD is confronted with the same situation, they too use screws.
I use #8 Stainless steel screws,  pre-drilling the holes in the caps slightly bigger than the diameter of the screws, to prevent cracking of the caps.
