Topic: Tank sensors (Read 198 times) previous topic - next topic
Tank sensors
I had my 1992 MB for seventeen years and the original sensors all worked fine. I was surprised when I discovered the seniors in our new to us 2004 MB don't function at all!  I've read all the advice on in the handbook and looked through the archives. I've tried the various "fixes" suggested for cleaning the tanks but no improvement. We are thinking of going with the Horst sensors because of cost and they seem to be more of a DIY project.
We'd like advice on installation. Another question is that the fresh water also reads empty. Horst doesn't even have a replacement. I'm thinking that there must be a connection issue rather than fouled sensors.
2004 MB
Re: Tank sensors
Your problem is an electrical one, Horst sensors are only good for tanks that display full when actually empty.
Horst sensors are replacements for the stock pick-up sensor pins, installed in the gray and black tanks.
Horst Mircacle Probes - Get accurate reading on your RV's holding tanks
If you cannot fix the stock panel, the tanks can still be monitored by installing a SeeLevel sensor kit.
They accurately measure the fluid level and display, on a digital readout, the percentage of tank filled.
They do not plug up, the sensing is done from outside the tank electronically.
Many of us have used SeeLevels for 10-15 years.
709 SeeLeveL IIâ„¢ Tank Monitor System - Garnet Instruments
Amazon.com: SEE LEVEL 709: Automotive
It's a nice upgrade that gives a much more accurate measure of remaining capacity of the fresh, gray, black and propane tanks.
Re: Tank sensors
To add to Larry's post, when we went from an '83 to an '04, I was struck by the uselessness of gauges that increment in thirds! At least the ones in the old rig read out in quarters, still marginal. The SeeLevel gauges read out in percent, in increments of about 4%. Accuracy is still only as good as the installation accuracy, but you do get a good feel and confidence for what is in the tanks after a little experience.
